Anyone one have a "custom" C3?
My car is changed from nose to toes so to speak....grill to tail lights...
only stock parts on the ourside of the car is the bumpers, and door handles...
GENE
GENE
Im going to be installing a tilt front end with fender flares built in, as well fender flares in the rear, then we're going to put on the 17 by 12 rims we got a little while back, we already have gymkhana springs and KYB gas-adjust shocks on all four corners, and a dual exhuast with chambered pipes, and sine you cant have all of that without some power to back it up we've installed a 650 cfm BG speed demon carb with an edelbrock performer RPM intake and a wilder summit cam and lifter kit, as well Willwoods superlyte 4 piston calipers on the front to get it to stop. Hopefully in the end itll be one of the more one of kind vettes on this forum
do you have the tilt front end yet?
[Modified by killervette666, 12:03 PM 7/6/2004]
[QUOTE]Well - my '68 is mostly custom.. Hardly any stock parts left...
/QUOTE]
Saw your Vette at the tower shops on Friday, where I also to a pic of this thing. Sorry for the crappy picture phone quality. Yes, it is diamond plate bracing up the exahaust.
/QUOTE]Saw your Vette at the tower shops on Friday, where I also to a pic of this thing. Sorry for the crappy picture phone quality. Yes, it is diamond plate bracing up the exahaust.
you'd be hard pressed to find a single stock part on this car.
Double click to enlarge
[Modified by norvalwilhelm, 8:51 AM 7/7/2004]
, if you want to keep the pop up headlights youll need to do some fabricating, thats why i just decided to mount them in the grille like on GSC3 corvette, that way i can also save tons of weight by removing the entire pop up assembly
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
/QUOTE]
[Modified by GrandSportC3, 12:51 PM 7/7/2004]
Yours must be made of lead, mine don't weigh a lot at all, hardly something worth saving weight on.
