1st flare done
Old Jul 7, 2004 | 05:06 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Re: 1st flare done (Rolling Thunder)
I'm sory not a fan but it is your car and good job on your work, and fiberglass skills
Old Jul 7, 2004 | 05:29 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: 1st flare done (Nowhere Man)
I'm damn impressed
Old Jul 7, 2004 | 05:32 PM
Twin_Turbo's Avatar
Twin_Turbo
yea, it ain't exaclty for the NCRS crowd
Old Jul 7, 2004 | 05:36 PM
Corz's Avatar
Corz
Default Re: 1st flare done (Twin_Turbo)
yeah it is
just not the BIG one
Old Jul 7, 2004 | 05:37 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 1st flare done (Corz)
I actually have a pair of decals from the special NCRS crowd They will be fiven a prominant place somewhere on the car.
Old Jul 7, 2004 | 08:56 PM
76REDSTINGER's Avatar
76REDSTINGER
web address for mad?
thanks
R/.
Old Jul 7, 2004 | 09:42 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
it looks a little bit big. Are you patterning it after a design the red car maybe or are you just free handing it?
Old Jul 8, 2004 | 09:59 AM
Twin_Turbo's Avatar
Twin_Turbo
thanks
R/.
http://www.madvet.com/
Old Jul 8, 2004 | 10:01 AM
Twin_Turbo's Avatar
Twin_Turbo
They need to be big to house my bigazz wheels and tires, and I have to run 3/8 inch spacers (or thicker rotor hubs) to clear my calipers, all that amounts to flares that are this wide. They are still a tad too wide so I can trim the edge to exactly where I want it with the wheels mounted and the car level
Marck
Old Jul 8, 2004 | 11:00 AM
StingrayDK's Avatar
StingrayDK
very impressive
Old Jul 8, 2004 | 11:39 AM
Birdie2000's Avatar
Birdie2000
Very good job.
You plan on racing this car, or are the wide tires purely for looks?
Old Jul 8, 2004 | 12:18 PM
Twin_Turbo's Avatar
Twin_Turbo
Well, I live very close to the german autobahn...soo....
Old Jul 8, 2004 | 02:14 PM
  #33
Twin_Turbo's Avatar
Twin_Turbo
Also decided to permanently attach my fiberglass rear bumper since the not so cheap thing didn't fit worth a damn
Still got to do sanding there and filling, and sanding...and...uhhh.. lotsa work.
Thinking about putting the oil cooler for the diff behind the license plate frame (and cutting the center of that section out), then move the plate somewhere below it but I'm not 100% certain it'll look good. I need to find a place for the diff cooler and maybe also for a tranny cooler... decisions decisions. Also still need to fit the dry sump tank, as it looks now I will have to cut the trunk floor.
Old Jul 8, 2004 | 02:56 PM
  #34
Corey_68's Avatar
Corey_68
Looks great! I SO wanted to add flares, bit I couldn't stomach cutting the car up. :
Old Jul 8, 2004 | 05:46 PM
  #35
Missileman's Avatar
Missileman
Sweet.
Old Jul 8, 2004 | 08:48 PM
  #36
jetech's Avatar
jetech
Looks great.
How did the glass work go?
Old Jul 8, 2004 | 09:51 PM
  #37
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
They look really sweet! Great work!
To 1st flare done
Old Jul 8, 2004 | 11:50 PM
  #38
burners's Avatar
burners
Cruise-In V Veteran
That's looking good, Twin_Turbo. As always you do good work and have some great ideas.
Old Jul 9, 2004 | 08:03 AM
  #39
Twin_Turbo's Avatar
Twin_Turbo
Glass work is pretty easy once you get the hang of it. I did some mods to the flare section, I laminated a couple of layers on the edge so I can get a nice rounded of lip, I hate the flat sides like the stock fenders have. Also trimmed it so it ties exactly into the section just behind the door. It's going a whole lot better than I could have ever hoped. There are no air bubbles in my flare yippie
I glassed up the antenna hole, don't need no stinking radio when you got V8 fm playing loud.
Next will be the other side, then the front and then I will have to make close fitting enclosures to duct to and from the intercoolers. Side skirts are on the list too. Been thinking about putting a slight notch in the frame and run a muffler exit under there. I have oval tubed mufflers so they won't sit very low. Only thing I have to do is modify the floor because there's a lower sections where the seat belt retractors on early models went, it's gotta go. I will then mold the skirt to closely fit around the muffler exit.
Old Jul 9, 2004 | 08:48 AM
  #40
vincevette78's Avatar
vincevette78
It really looks nice. Are you making a mold of the flares?
