Battery Draining
Old Jul 9, 2004 | 09:28 PM
katt68's Avatar
katt68
6th Gear
Default Battery Draining
My father-in-laws 1978 indy pace car has a draining battery.
the battery is new, and fully charged but for some reason there is a drain killing the battery.
has anyone encountered this problem before and if so...what should i be checking ?
Old Jul 10, 2004 | 08:21 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
my `87 kept killing the battery, & the mechanic told me it was a bad alternator. The car would drain even when it was shut off. I also had put a new battery in it right before I took it to him ( 3 days ) He said it would not hold a charge, & that when the alternator goes bad, it can also destroy the battery. I replaced the alternator, & went back to Sears, & they replaced the battery. So far, So good.
Ken :flag
Old Jul 10, 2004 | 12:36 PM
jfb's Avatar
jfb
Pull the negative terminal on the battery and place an ammeter (VOM test meter set to amps) between the battery neg term and the cable lug. This will allow you to measure the leakage current which should be less the 50 milliamps (my 87 draws 27 ma.). Then pull fuses one at a time and look for a sudden drop in leakage current. The circuit that fuse is on will then have to be checked for the offending device drawing the excess leakage current. Make sure at night that the map light and/or the overhead light isn't on. Does he have an aftermarket radio, audio amplifier, radar detector, car alarm? If so, they are suspect. Also, remove the output wire on the alternator (be careful not to touch the wrench to ground or you will harm your VOM, or you could disconnect the VOM and then remove the alternator wire).
Old Oct 25, 2004 | 07:42 PM
mitchcole's Avatar
mitchcole
Is this right - on the negative side??
I've got the same general problem...
....revived from the dead....
Old Oct 25, 2004 | 08:27 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
moving to "C3" where others who own the same generation may have a more detailed answer.
To Battery Draining
