I am looking at these and am just wondering if anyone has had any good experiences or bad ones, thanks alot in advance for any help. I am also looking at the crane energizer ones too.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Check put the Harland Sharp roller rockers they are good rockers and about the same price as the one you are looking at.
They are imports and will work OK with mild spring pressure. I've seen the roller end get deformed and have roller get loose with stout spring pressures on a small block. The Omega brand stuff is about the same.
Personally, I think you're better off with something else. The Crane Energizers are a relatively low cost set (used to be sold under Cam Dynamics name) and work fine. I ran a set on my 427 for over 20 years before they started getting wear on the trunnions. Never had a failure and I twisted them in the 7500 rpm range regulary as well as cross country trips. I'd use another set in a heartbeat on a hot street engine.
The Harland Sharps are also great. They originally made them and Crane came up with the Gold rockers from them. Way back when I believe Sharp actually made the Cranes for awhile. Great rockers if you can find a deal on them.
Of course Crower (AKA Schneider) are great too. The Comp steel ones with the huge trunnion are killer too. I've got a set of them on my 540.
JIM
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I wore out a set in 4 to 5,000 miles of street driving. They are junk, stay away from them. Nothing else was worn or damaged on my then 90,000 mile engine, they just went to pieces. I now have Comp Cam Pro Magnums. Worth the money. BTW, the Proforms are made in China, something I didn't know when I bought them. Not on my engine again, no way.
I ran Proforms a couple of years ago on a roller cammed small block. They lasted maybe six months before trashing all 16 trunion bearings. Buy something a little better.
