Help!! 82 died on me today
Old Jul 13, 2004 | 03:41 AM
Twin_Turbo's Avatar
Twin_Turbo
Yes, the est is in the module. There's no telling, just trial and error. Be sure to use liberal heat sink grease
The problem here is that if the RPM signal is dead a code would be tripped but it would be code 12 which is, becasue of system design, always tripped if the ignitionis turned on with the engine not running (no RPM signal also)
Old Jul 13, 2004 | 04:01 AM
71coupe's Avatar
71coupe
Originally Posted by Blue70
Every once in a while the car will start for a couple seconds and idle real rough, as soon as you touch the gas the engine starts to cut out
Sometimes an EGR valve will stick open and cause the exact thing. That's easy enough to check, pull it off & see if there is an excessive carbon buildup
