Leaky intake gasket
Old Jul 15, 2004 | 09:20 PM
aharte's Avatar
aharte
Default Leaky intake gasket
I noticed that a bit of oil is seeping out around my intake. It even bubbles up a little in one place with the engine running. Is this something I need to worry about?
Old Jul 15, 2004 | 09:37 PM
checklst's Avatar
checklst
New gasket time!!!!!!! Sometimes it can cause big headaches with an erratic idle, causing of a lean out condition. A lot of non necessary carb adjustments are made because of a vacuum leaks and general mess with all the vacuum operated systems.
Old Jul 15, 2004 | 10:25 PM
Older Than Dirt's Avatar
Older Than Dirt
A guy I know put a new set of valve covers on his car. His intake had small bubbles seeping from one spot. I noticed he had installed the pcv valve in one side and had a filler cap installed in the other. I told him to take the filler cap off and install a breather cap in its place. He did this and the leak stopped. Maybe your pcv system is closed up?
Old Jul 16, 2004 | 05:21 PM
glen242's Avatar
glen242
Around the intake - head junction or around the intake to head bolts? Leaks are quite common around the intake bolts themselves if thread sealer was not used. If intake - head junction, new intake gasket is needed.
Giving more thought to the problem, where exactly is the bubbling? Is it from the intake end seals?
Old Jul 16, 2004 | 08:49 PM
aharte's Avatar
aharte
The leak looks like its mainly around the bolts, but the bubbling is at the intake-head junction. Its right between the two bolts near the carburetor on the driver's side.
Or it was. I checked the tightness of the bolts, and most of the ones I checked were loose -- carb, valve cover, and intake bolts . Now the bubbling went away. There might still be some leaking though.
It definitely did something though. I was having a problem with gas in my exhaust, and that seems to have gone way down now.
Is it normal for the intake bolts to be cap-heads? It seems like a ridiculous place to put them. I couldn't fit a torque wrench in there, and even a little hex wrench could only get to half the bolts (if I disassembled a bunch of stuff, then I could have gotten to more).
Old Jul 16, 2004 | 08:54 PM
comp's Avatar
comp
cap-heads i like the looks i didn't read if there was washers???
Old Jul 16, 2004 | 09:04 PM
aharte's Avatar
aharte
No washers. Just 5/16 cap head bolts.
To Leaky intake gasket
