Help!! Stuck in Reverse
Old Jul 16, 2004 | 06:40 PM
foundvettelifeisgood's Avatar
Default Help!! Stuck in Reverse
Was getting ready to wash it for the Vintage Grand Prix tomorrow, and the reverse interlock is not clicking out. So I have reverse and neutral. That's it.
What's the fix???
Old Jul 16, 2004 | 07:24 PM
I just crawled under and worked the reverse linkage by hand. Nothing. Please help.
Old Jul 16, 2004 | 08:39 PM
ttt
Old Jul 16, 2004 | 09:35 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I had mine stuck in 3rd once Jay. Happened when I had the Vette out in cold January. Shifter and linkage were cold and got all jammed up. I jacked the car up and loosened the shifter rods at the tranny. I think they somehow got jammed on a down shift. I loosened wiggled the rods around and re-tightened.
Hope that's your problem.
Are you going for the show?
Old Jul 16, 2004 | 09:37 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Oh, after you loosen them, try to put the shifter into neutral. Then the rod ends should point straight up and the reverse lever is pointed to the back(I think).
Old Jul 16, 2004 | 09:51 PM
I'll give it a try in the morning. I'm so :mad
I was thinking Grand Prix, Yankee Lake and Colussy next Sunday.
Old Jul 16, 2004 | 09:54 PM
I can't help but think it has something to do with the reverse T pull. It's not disengaging. What does that T pull mate with?
Old Jul 16, 2004 | 09:55 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
I have a Hurst shifter though. I don't have the reverse lock-out.
If it doesn't rain, I was going to try to hit the race on Sunday, 12-5 I think. If I don't have to drive anyone around either.
Old Jul 16, 2004 | 10:00 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
sounds like a problem with the carrier bearing...
Old Jul 16, 2004 | 10:08 PM
RHD '68 L89's Avatar
RHD '68 L89
Sounds like the 1-2 gate is out of alignment and is stopping the shifter from returning to the forward gears. It may be that you snatched reverse and the 1-2 lever hooked up with it not allowing the shifter to return.
Check the 1-2 lever on the box to see if it is fully in the neutral position. The shifter rod may have bent and while 1-2 is in neutral on the box the shifter gate is a little off stopping the shifter returning to the 1-2 gate.
The reverse lock out just stops the lever moving into the reverse gate. When you return to the 1-2 gate it drops back to it's normal position. Can't see how it would cause this problem.
Oh, and check you haven't lost one of the shifter mounting bolts. If the shifter can rotate around only one of the bolts it would cause these symptoms.
Probably a good idea to realign the whole shifter once you find the problem.
Old Jul 18, 2004 | 03:29 PM
RHD--You nailed it!
Old Jul 18, 2004 | 05:07 PM
RHD '68 L89
Glad I could help.
What was it exactly?
Old Jul 18, 2004 | 08:44 PM
The 1-2 alignment. The shifter grease was gummy and probably a contributor. I hit it with WD-40.
Old Jul 19, 2004 | 04:28 AM
Turbo-Jet's Avatar
Turbo-Jet
i once got stuck in 1st and Reverse at the same time
/pause/
yep just had an earthquake in Vancouver
woah, swaying at 20 stories high is a little scary
anyhoo, time to readjust linkage and rebuild shifter?
i've also had my car pop out 1st a few times with a rather large bang...
To Help!! Stuck in Reverse
