Subwoofer Recommendation / Mount
Old Jul 19, 2004 | 08:57 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Subwoofer Recommendation / Mount
Anyone mounted a subwoofer in the storage compartment? Seems like it would be a good place for an 8" with a conceiled enclosure.
Thanks...
Old Jul 19, 2004 | 09:01 PM
Jasonty's Avatar
Jasonty
Not a bad spot to mount an 8", but if I were gonna install subs, I'd ditch the rear speakers, and mount them back there with some custom fab cutting. Cleaner, and you really don't wanna lose that storage space, since it's not very plentiful in our cars anyways...
Old Jul 19, 2004 | 09:11 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Why would you put a sub in the storage compartment?
I don't think it would sound good at all.
Old Jul 19, 2004 | 10:20 PM
MN-Brent's Avatar
MN-Brent
Kenwood Woox -powered sub
This has the AMP built in. I run the 6x9s with the sony CD player only. Fronts + 6x9s + Woox = pretty awesome sound in the cabin.
Puts out more bass than you will need without getting stupid!! IMHO.
Brent...
Old Jul 19, 2004 | 10:27 PM
FeedVaal's Avatar
FeedVaal
Plenty of room back there,,,,
Old Jul 20, 2004 | 09:30 AM
Garys '68's Avatar
Garys '68
I replaced the 3 doors with a single door. I mounted 3 DVC 8" subwoofers on it. Top is carpeted and there are just slots cut to give any indication that there are speakers in there. Sounds great, hardly noticable.
Gary
Old Jul 20, 2004 | 09:39 AM
Crash80's Avatar
Crash80
I am running the same sub as M-N Brent. It is a great little compact unit with plenty of power for the little cabin of an '80 and gives the 6X9s the oomph that they lack. If you are looking to rattle your licensce plate or make yourself sterile from low end, then this is not the sub for you. I dig it because I don't loose any of the precious T-top storage real estate to acres of amps and drivers usually associated with subs. Infinity makes a similar setup to the WooX but it is a little bit bigger. I believe it is called the Basslink. It was too tall to mount where mine is mounted, very similar to MN-Brent's location. The Woox also comes with a little wired remote so you can dial in how much sub you want in relation to your other speakers, as well four selectable frequency roll off points and wheather the sub is firing in phase, or 180 degrees out of phase with your other speakers.
CVT4ME
Old Jul 20, 2004 | 09:02 PM
ultimix's Avatar
ultimix
A Friend of mine built this speaker box - really looks great and sounds AWESOME.. I have had it for a 1 year or so. He said that he would do more if there are interests.
Mark
Old Jul 20, 2004 | 09:03 PM
ultimix's Avatar
ultimix
Here is another photo - The top fits great with out a problem - just to let you know -
Mark
Old Jul 20, 2004 | 09:29 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Default sub
I installed a Bazooka 8" sub with built in amp in the storage space of my '82, held down with velcro straps anchored to be back. The sound is great, I have the sub volume at about 1/4, any higher than that and the doors start bulging.
Old Jul 20, 2004 | 09:56 PM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Old Jul 21, 2004 | 09:33 AM
Motor City Vette's Avatar
Motor City Vette
Mark
Ultimix,
What type of speakers are in the enclosure?
Thanks.
Old Jul 21, 2004 | 10:26 AM
Tomi72's Avatar
Tomi72
I have a 10" in the storage compartment, it's a very tight fit, 8 incher should be much easier to install. I made a glassfiber enclosure for the sub and just dropped it in there.
Old Jul 21, 2004 | 01:17 PM
slaine's Avatar
slaine
MN-Brent CVT4ME- Thanks so much guys for your information. Last spring I decided that when I got the time this fall, that I was gonna overhaul my speaker system in my '80. I've got two six by nines in the back, two four by six's in the dash and two round fours in the kick panels. I was LUSTING after the wOOx but I didn't know if it was worth the $230.00 asking price. I could use any advice on replacing the other speakers. My system is 15 years old. The head unit is an old JVC cassette player 4x20 watts that fits the console panel properly and it goes through a tiny amp in the glove box at 4x200 watts. Orignally the system was very strong 15 years ago. So I wanna replace my speakers and add a wOOx. ANY advice on replacement speakers would be muchly appreciated.
Mike
Old Jul 21, 2004 | 01:49 PM
80TexasC3's Avatar
80TexasC3
Brent...
Brent... Very nice! My only issue is that I've already used the space...
Old Jul 21, 2004 | 01:50 PM
80TexasC3's Avatar
80TexasC3
DAMN! do you need ear plugs?
Old Jul 21, 2004 | 01:53 PM
80TexasC3's Avatar
80TexasC3
Tomi72
that is exactly what I'm looking for... with the exception that I have a two door vs three door compartment. How hard was it to build the box? Could I use MDF as I did in the rear? I used Fiberglass in the front but had a heck of a time and had to get help.
Ed
To Subwoofer Recommendation / Mount
Old Jul 21, 2004 | 02:07 PM
Crash80's Avatar
Crash80
Hey Slaine,
You can get a Woox cheaper than $230.00. I think I got mine off of E-bay for about $170.00 or so, and it was new. Here are a couple on there right now.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
They appear to be from the same dealer but you can get an idea of what you can get them for.
As for replacing your other components, I can't help you. I am not a stereo hound like some of the folks on here. If I were you I would integrate the WooX into your exisiting rig and see what that does for you. Then I would start replacing your other components as you see fit from there. I am running 4X6s in the dash and some 3-way JVC 6X9s in the rear with a JVC CD AM/FM tuner of some kind that is probably rated 40 watts per channel. This stuff was put in by the previous owner and while not a powerhouse rig, it is plenty for the little cabin of my C-3. The Woox just gave it the punch it was missing which is exactly what I was looking for. If you want to get options from guys who really know car audio, go over to the audio/electronics section of the forum.
http://forums.corvetteforum.com/forumdisplay.php?f=20
Best of luck!
CVT4ME
Old Jul 21, 2004 | 02:40 PM
slaine's Avatar
slaine
CVT4ME Thanks, that helps a lot. I gonna get that wOOx and install it just to see how much it helps. My wife, an audiophile and talented singer says my current 15yo six speaker set-up sounds like a "cell phone". DOH! You've saved me money already, thanks.
Mike
Old Jul 21, 2004 | 03:06 PM
FeedVaal's Avatar
FeedVaal
Tomi72,
Just want to say that your's is one of the best looking mods to that compartment I've seen yet.
