will paint stick to chrome?
Thanks,
DM
Steps to take would be as follows
1) tape off all areas that you do not want to scratch
2) tape over the tape in step one because you WILL accidently sand through at least one spot
3) Use no less then 800 grit to start, Working you way to 1000 grit
4) When you are done sanding clean the areas THOROUGHLY with air (you can use water but be SURE to get the areas completely dry)
5) clean the areas with a tack rag with some grease remover on the rag (remember to keep the tape on the pipes some solvents will ruin chrome!)
6) Prime, and paint
If I missed anything someone will let me know I am sure
Good luck
Rob
