'77 auto trans question
Old Jul 21, 2004 | 01:48 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default '77 auto trans question
I just started to notice that rpms seem higher at all speeds. I'm guessing that the trans is slipping some..am I correct? And also when I nail it the tach goes way over fast...
.....for example..when I used to go 40mph the tach would read around 2000...now at 40mph it reads over 2500...sounds like a slipping transmission to me...?!?
Can the bands be adjusted or does it need a rebuild and what would be an average cost to rebuild the transmission...
Thanks for your help.....
Oh yea also I've had the vette since 1982 and it now has 125,000 original miles on it...runs perfect otherwise...
Old Jul 21, 2004 | 03:21 PM
Schmucker's Avatar
Schmucker
I'm sure it can be adjusted, but a good light performance rebuild on a TH350 is only a couple hundred bucks.
Old Jul 21, 2004 | 11:25 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks for the reply...I have been quoted from several shops between $500-$750...and chevy dealerships even more...so thats why I was wondering...If you say it can be adjusted why would I want to have it rebuilt?...
Any other opinions would be appreciated...I know there are more guys here with C3's that have good knowledge of what I need help with...Thanks again...
Old Jul 22, 2004 | 12:36 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Band adjustment? NO
That term was forgotten about in the sixties or early seventies and the last transmission that I know of that offered band adjustments was the Ford C4 used in Mustangs and Fairlanes.
The GM trans should not slip. It is not adjustable. Is it full of fluid? Have you ever serviced it since you had the car, all these years?
Old Jul 22, 2004 | 05:25 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Yes and yes...I have changed oil every 2500 miles with a filter and have changed trans fluid and filter 4 times since I bought it in 1982 with 50,000 miles on the clock, so it has not been neglected in any way...
So I guess I just need a rebuild with new clutches and gaskets...surprised that no one else had an opinion...
Old Jul 22, 2004 | 05:31 PM
page62's Avatar
page62
Is your tach accurate? When it goes "way over" do you hear the corresponding engine revs?
This would be a GOOD time to put an overdrive transmission in there!
Old Jul 24, 2004 | 12:54 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Yes it has always been accurate and is still accurate...it flies over to 6-7000 rpm and the engine sounds like it also...but it goes there way too fast..so that to me means the trans is slipping...
Old Jul 24, 2004 | 01:00 AM
Stoge's Avatar
Stoge
any chance it could just be a screwed up torque converter?
Old Jul 24, 2004 | 01:13 AM
Schmucker's Avatar
Schmucker
Geez, I can get a mild performance TH350 rebuilt for $125. It's not a shop, just a guy that does it himself in his garage, but I wouldn't expect a shop to be charging that much more.
Old Jul 24, 2004 | 02:50 PM
z3man987's Avatar
z3man987
i had my th350 rebuilt for about 200-300 i think, but a high performance rebuild. just look for the little shops, dealers jack prices real high. i learned about my guy from other guys who work on my car recommending... if u live near san diego or oceanside, i can tell u where he is.
Old Jul 24, 2004 | 09:48 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks for reply...I am about as far across country as you can get...Virginia... ...so I guess I will look here..and it may be my torque converter as somebody suggested...who knows...guess I will have to take it somewhere to find out..thanks for help and if anyone else wants to chime in I will be all ears and appreciative..thanks guys...
Old Jul 24, 2004 | 11:46 PM
comp's Avatar
comp
it can be you need to check and try a fuild service
Old Jul 26, 2004 | 12:28 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
will do this week...thanks
To '77 auto trans question
