C3 high speed stability?
Year/ bhp needed at 130 mph/ Front Lift (lbs)/ Rear Lift (lbs)
'63/ 108/ 254/ 163
'79/ 143/ 220/ 183
'80/ 126/ 155/ 24
'84/ 97/ 148/ 55
Not a very graceful piece of machinery. Let's hear it for rear spoilers.
I know from the feel of the car with the rack in it now, it's more than capable of brown staining most anyone, especially with top and windows down....
I hate to appear smug, but in fact, doing 120+ in a coupe is nothing, do it with top and windows down....it's entirely another horse.....
GENE
Been there, done that to.have fun
At 125 a C5 feels like it does at 25!
SammyB, how did you get up to 120 mph??
In Colorado we have some open farm roads in the Eastern part of the state that are all good for speed!
PS: Oh yeah and after I slowed down to the speed limit, I passes a highway patrolman coming the other way. Two rushes at once.
GENE
The C3 is not as good aerodynamically as most newer cars; but it isn't all that bad either. Keeping air from passing under the car serves 2 things:
1) The bottom of the car is not as smooth as the shiny side and creates a great deal of wind resistance. My ZO6, and to even a greater extent new Ferrari's, have smooth bottoms for this reason.
2) Keeping air pressure from building up underneath the car helps keep the nose down. If air is block by a deep chin spoiler it is possible to even have a lower pressure under the car which can help suck the car down countering the lift generated by the arched fenders above.
A stiff set of springs greatly help rear end squat and front end lift. Most current C3's have a tendency to sit very high at the nose which exacerbates the problem. Get the car to sit like it was meant to!!!
Lowering the car makes them much more aerodynamic and stable. "Hydroplaning even at low speeds" as was earlier stated has absolutely nothing to do with aerodynamics and everything to do with tire selection. Loose, tired suspension components has been my most common experience with cars, any car, at higher speeds.
I would strongly dispute the published figures showing a 79 needing more hp to obtain 130mph than a 63 vette. I have seen numerous published figure elsewhere to counter this. Drag coefficients for the C3's are also all over the map, anywhere from .36 as stated earlier to nearly .50.
Bottom line for me is that from the article referenced by lostpatrolman regarding the Heinz Lemans vette running 212mph on the Mulsanne straight shows the car to be absolutely stock in shape except for the extra deep chin spoiler. Something anyone of us to copy pretty easily and simply bolt on. All you would still need is an honest 500hp at the rear wheels and gears/tires spec'd for such a speed.
Chuck
2) Keeping air pressure from building up underneath the car helps keep the nose down. If air is blocked by a deep chin spoiler it is possible to have a lower pressure under the car which can help suck the car down countering the lift generated by the high arched fenders above.
Lowering the car makes them much more aerodynamic and stable. "Hydroplaning even at low speeds" as was earlier stated has absolutely nothing to do with aerodynamics and everything to do with tire selection. Loose, tired suspension components has been my most common experience with unstable cars, any car, at higher speeds.
I would strongly dispute the published figures showing a 79 needing more hp to obtain 130mph than a 63 vette. I have seen numerous published figure elsewhere to argue this. Drag coefficients for the C3's are also all over the map, anywhere from .36 as stated earlier to nearly .50.
Bottom line for me is that from the article referenced by lostpatrolman regarding the Heinz LeMans vette running 212mph on the Mulsanne straight shows the car to be absolutely stock in shape except for the extra deep chin spoiler. Something anyone of us can copy pretty easily and simply bolt on. All you would still need is an honest 500hp at the rear wheels and the right gears and tires.
Chuck
I have new heads and headers now which must have greatly increased my top speed potential, but it needs some tuning before I try it out... I had my '92 Camry to 140 two or three times, not too bad, but overdrive sure makes it a hell of a lot easier getting there!
-Chris
