Power Steering Control Valve
Old Jul 22, 2004 | 11:01 PM
Stoge's Avatar
Stoge
Default Power Steering Control Valve
Has anyone rebuilt their power steering control valve? Is this something I can do without screwing it up? Any special tools needed?
Old Jul 23, 2004 | 12:21 AM
VetteNut72's Avatar
VetteNut72
Just rebuilt mine. Can't tell you if it works yet but no special tools were required and it wasn't difficult. I bought the rebuild kit about 3 years ago (when I had money) and I think it cost around 40 dollars.
Craig
Old Jul 23, 2004 | 10:01 AM
Matt Gruber's Avatar
Matt Gruber
http://community.webtv.net/MATTGRU/Quickwaytoreseal
Old Jul 23, 2004 | 10:41 AM
87bob's Avatar
87bob
Veteran: Coast Guard
I just put one on from Van Steel, it works great, cost 80+change, and has a 5 year warranty. If you rebuild it yourself will your rebuild last 5 years? Plus their's comes pre-tested and adjusted. They do good work.
Old Jul 23, 2004 | 11:16 AM
Stewart's74's Avatar
Stewart's74
At first I went the rebuild route. Its a PITA. If your time is valuable to you get a rebuilt unit. after the rebuild, mine leaked worse than before, and balancing the unit wasnt fun.
A rebuilt unit should be factory balanced. Just install and drive.
Old Jul 23, 2004 | 11:49 PM
Stoge's Avatar
Stoge
Is the vansteel part an exact replacement i.e. same factory part number?
Dan, if you're lurking and can shed some light I would appreciate it. If your part is "plug and play" so to speak that would be real cool.
Old Jul 24, 2004 | 12:28 PM
Stoge's Avatar
Stoge
ttt
Old Jul 24, 2004 | 12:30 PM
Stoge's Avatar
Stoge
t t t
Old Jul 24, 2004 | 07:37 PM
stickboy's Avatar
stickboy
I rebuilt mine and it started leaking again in under a year. I bought a rebuilt one from Autozone and it has a lifetime warranty. If it starts leaking take it back.
Old Jul 24, 2004 | 08:47 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yes it's an exact replacement. Here a link so you can check it out.
http://www.vansteel.com/index.cfm?fu...ups&Group=7000
Old Jul 25, 2004 | 01:26 AM
Stoge's Avatar
Stoge
Old Jul 26, 2004 | 10:36 PM
trw's Avatar
trw
Matt,
What is the spool depth?
Are you leaving the ball attached and removing the body?
Terry
To Power Steering Control Valve
