Replacing power window assembly
Old Jul 23, 2004 | 08:30 AM
virtue4u's Avatar
virtue4u
Default Replacing power window assembly
I removed the driver side window assembly when I saw that the gear teeth were worn and the bracket cracked. (The gear on the motor looked OK). Something tells me that installing the new assembly and getting it adjusted correctly may be a "bear."
I'm sure someone has done this before. Please, provide me your tips and advise. Is there a step-by-step procedure that someone can post?
Old Jul 23, 2004 | 10:27 AM
72GACRZR's Avatar
72GACRZR
Final window adjustment is a bear, the rest is easy. Look in an service manual, most have the step by step instructions.
Old Jul 23, 2004 | 03:05 PM
stingray4me's Avatar
stingray4me
Default power window c3
http://www.corvetteclubcentralga.org...embersmenu.htm
heres the project I put on my clubs web page
Old Jul 24, 2004 | 11:01 AM
virtue4u's Avatar
virtue4u
What lubricant should I use on the assembly? I think WD 40 is too light. Silicone oil may also be too light. What about white lithium grease? Is that too heavy?
Old Jul 24, 2004 | 10:01 PM
vettemack's Avatar
vettemack
I used the white lithium on mine.
Old Jul 25, 2004 | 11:10 PM
virtue4u's Avatar
virtue4u
I installed the power window assembly (without the glass) and re-installed the motor. It's easy and moves just fine. I'm waiting for new glass.
To Replacing power window assembly
