Dynomax Header fit.....help
Old Jul 25, 2004 | 09:17 AM
rfun'71's Avatar
rfun'71
Default Dynomax Header fit.....help
Installed a set of ceramic coated Dynomax on my '71 350. No problems with install but noticed when I went to put on the reducer that it comes within 1/2" of hitting the bottom of the foot well. Don't see how an exhaust plus clamp will go on without touching (melting) the fiberglass. Instructions say for fit adjustment to loosen the motor mounts and shift the engine. Never heard of that but maybe can be done.
Anybody incur this problem? What did you do?
Old Jul 25, 2004 | 11:15 AM
comp's Avatar
comp
Hmmmmm does sound strange, i have made small changes with sloting
the mount bolt hole's on different cars
Old Jul 25, 2004 | 12:08 PM
PRNDL's Avatar
PRNDL
I might try a thin sheet of stainless to use as a heat shield, maybe try a band clamp, look into welding. I would try many different options before attempting to reposition the engine via motor mounts!
Old Jul 26, 2004 | 11:00 AM
Stewart's74's Avatar
Stewart's74
I have those headers on my 74 and they fit great. No issues at all.
Old Jul 26, 2004 | 11:09 AM
Mr.Gearhead's Avatar
Mr.Gearhead
Whooops... I never heard this one before. Mine are on... but my body is not. I hope this isn't an issue. Although I did weld mine after the collector.....
http://temp.corvetteforum.net/c3/bendera/header.jpg
Also... I turned my collector flange so it is flat on the bottom and the peak is at the top ( to ensure clearance) Do I need to spin it around so the body doesn't hit the peak?
Old Jul 26, 2004 | 01:16 PM
rfun'71's Avatar
rfun'71
Stewart '74
How close is your reducer to the floor pan?
I see you have an automatic. My brother just installed the same set in his '78 automatic and his clears by 2 1/2 inches. His part number is slightly different as well. Think it is because his is an auto and mine is a 4 spd. I have a call in to Dynomax with no response yet.
Mr. Gearhead, I will let you know what Dynomax says. Is yours a 4 spd?
Measuring from the bellhousing to the collector, the collector is 1 inch closer to the bellhousing on the driver side vs the passenger side putting the passenger side header too close to the floor pan. By the way, what number do you have stamped on the collector. Mine has two numbers on each: 303 on the top and 008 on the bottom. My brothers is 502 and 008. Thanks
Old Jul 26, 2004 | 03:10 PM
CruisinCO's Avatar
CruisinCO
I was just about to order these for my 69 350 with 4 speed.... Interested in the results as I think your 71 setup is prob like my 69.
Old Jul 26, 2004 | 03:19 PM
Stewart's74
Originally Posted by rfun'71
Stewart '74
Its at least 2.5 inches away from the floor.
Old Jul 26, 2004 | 03:55 PM
rfun'71's Avatar
rfun'71
Dynomax called back and sent me a drawing of how the tubes should look to compare to what I have. They said MAYBE they sent the wrong part number for the right side or it was bent incorrectly. They were very pleasant and helpful to this point. They also indicated they would send me a new set if I was not satisfied. We will see once I get home and compare. I will keep you guys posted if they send me a replacement.
Old Jul 29, 2004 | 05:26 PM
rfun'71's Avatar
rfun'71
Dynomax was not so willing to send me a new set on the second day of conversation. They did send me measurements of the collector to the number 8 port and also the measurement of the offset of the collector from mid point. My set checked out fine as far as the measurement goes so there was no need to send a replacement set.
There must be something else different about my setup that makes the clearance tight.
To Dynomax Header fit.....help
