Sparkplug Length
Old Jul 25, 2004 | 12:37 PM
My69's Avatar
My69
Default Sparkplug Length
Just bought a new set of ACDELCO plugs #R45TS. When I removed my old AC plugs (same numbers) they are about 3/16 of an inch shorter. Whats up with that? Is this going to make any difference? Are there two types of ACDELCO plugs with the same number? Any help would be appreciated.
Mike
Old Jul 25, 2004 | 01:46 PM
Paul L's Avatar
Paul L
I believe you are speaking of the porcelain end and not the extended electrode tip. I have seen this before when I had my 1979. I do not know the reason but I can assure you that no change in performance is the end result. But it is curious. It might be a result of AC Delco outsourcing its spark plug production to non-USA suppliers such as NGK. But that is pure speculation.
Old Jul 25, 2004 | 02:16 PM
Chris69's Avatar
Chris69
I just purchased some Delco R43TS plugs yesterday, and the overall length was also shorter by that amount... Better for the guys with headers, I guess.
Old Jul 25, 2004 | 03:10 PM
My69's Avatar
My69
Thanks for the responses guy. I am talking about the thread end being longer. I appreciate any help on this.
Mike
Old Jul 25, 2004 | 07:25 PM
Paul L's Avatar
Paul L
Mike,
I'm cashing in for the evening so will leave this one in the hands of others. I don't recall the threaded area of the plug being longer. But again I will leave that with more informed opinions.
Old Jul 26, 2004 | 08:58 AM
GTR1999's Avatar
GTR1999
Ttt
Old Jul 26, 2004 | 10:44 AM
stingr69's Avatar
stingr69
What you need to look at is the length from the "seat" on the plug. The distance from the tapered seat to the farthest end of the thread dimension should be the same. The extended tip is not part of the thread, it is part of the insulator/electrode.
If the threads will protrude into the chamber, this is bad. If the threads will not screw in all the way, this is bad too.
-Mark.
To Sparkplug Length
