Need some help with a Holley
I was changing the waterpump on an RX-7 with a Holley 4160 and suddenly it won't idle. It could be vacuum (though not in the manifold - checked everything) or it could be the carb. I swapped on a new carb and manifold and everything runs fine. I've rebuilt the Holley a second time and there's still no improvement. At part-throttle, it surges, spits and backfires constantly, though full-throttle runs like a dream (vacuum secondaries). Can you guys tell me what common Holley problems are that might cause this? I only have 4 runners that feed a total of 2 rotors, so each rotor gets one primary and one secondary barrel, yet the rear rotor's primary barrel seems to flow a lot more fuel than the front. I'm getting uneven fuel delivery between the two primaries and don't know why. The whole carb has been exhaustively cleaned and I'm running 61 mains with the power valve blocked off (just the one metering plate).
Again, I don't want to **** anyone off here, just need some help on a Holley. If it helps, my roomie has an 89 L98 coupe.
Thanks.
Crit
Critteroso on AIM
678-467-0463
do you have the how to tune holley's book ??? if i was you i'd get it,
you need to stay on top of your tune with your car
My main question right now is this: How does a Holley idle? It doesn't seem like the primary boosters supply fuel at idle on a properly working carb (maybe it atomizes and I can't see it), but I would expect fuel to be metered through the base, right at the throttle plates to allow a measure of progression as you crack the throttle open. Is there an idle circuit in the base flange? I haven't noticed anything online mentioning one, but I would think so. Basically, I could use a little educating w/ respect to Holleys, so I figured the C3 guys would be the most likely to help.
Thanks again,
Crit
Thanks again,
Crit
