Looking for advice on spark plug selection
Old Jul 27, 2004 | 10:28 AM
Mpls Funk's Avatar
Mpls Funk
Default Looking for advice on spark plug selection
OK, with many thanks to all of U, my car is up and running. Now I am working on tuning it up a bit, etc…need to change the plugs and would like Ur opinion on what to use.
I have a 1970, 350hp/350 engine, double-pumper Holley carb (I’m told it’s way over carbureted…the previous owner raced it), Edelbrock intake, exhaust headers, standard coil/cap/rotor/points, it also has a different cam (but I know nothing about it…again, previous owner’s work).
The options I’m considering are –
AC Delco R44S – this is what the previous owner has in the car now
Autolite R84 – the previous owner used these plugs in the past
AC Delco R43S – the guys at NAPA recommended these for me
AC Delco Rapid Fire #2 – I’ve seen many of U here are using these
Champion somethings - this was being considered...but dropping out of the race
I don’t race the car or anything…but it’s always nice knowing you have the power if U want it - U know how it is! I guess I’m not sure if I will notice the difference going with the Rapid Fires or not? The guys at NAPA didn’t think I would? I would appreciate any recommendations from this group!!
Old Jul 27, 2004 | 10:37 AM
gkull's Avatar
gkull
When I had tapered peanut plug heads the best I found was Bosch P+4
The 4 tip makes it so you don't have to index the plugs.
Old Jul 27, 2004 | 11:01 AM
nhlgopens's Avatar
nhlgopens
I like the Bosch Platinums - been running them for over a year and haven't had the first issue. I run a hot coil and have them gapped an additional .010 for hotter spark.
74 L-82 Modified
Old Jul 27, 2004 | 11:11 AM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
I use the AC Delco platniums without any problems. I'm gonna try the Splitfire triple platinums in my car next time.
Old Jul 27, 2004 | 12:17 PM
Crash80's Avatar
Crash80
I would stick with the AC Delco plugs. The car was engineered to run these. If the plug that the previous owner was using works well in the car, then I would stick with those.
Old Jul 27, 2004 | 12:22 PM
Stewart's74's Avatar
Stewart's74
What is "Indexing"?
Old Jul 27, 2004 | 02:34 PM
lars's Avatar
lars
Stewart -
Indexing the plugs is when you make all the plugs align their electrodes in the same "clocking" relative to the combusion chamber. Idea is to get the "open" spark front of the electrode facing the chamber for improved and uniform flame front travel. There is some discussion whether or not this is actually effective in a street driven car... Plugs that do not use the conventional "J"-shaped negative electrode cannot be indexed.
By the way, I use standard Autolite resistor plugs. They are very easy to "read" when tuning and working on the car, whereas the platinum plugs burn so clean that they can "mask" problems that need to be corrected. I'm sure the platinum plugs have longer life, but I like the "readability" of the Autolite standard plugs, and there is no difference in power output with either plug.
Old Jul 27, 2004 | 04:31 PM
ettev's Avatar
ettev
Amen!
Platinums aren't the best choice for the older ignition systems. They're just not "hot" enough to justify platinums. They might have a tendency to foul quicker, as they don't accept any type of oil or fuel well, especially without the juice popping thru them to burn the stuff off.
Standard Bosch plugs for me. Work great. Never an issue.
Old Jul 27, 2004 | 05:22 PM
saudivette's Avatar
saudivette
I dunno if you can get them in the US, but I used to run Golden Lodge spark plugs in my race car. Can't remember if they were platinum or what, but they had 4 negative electrodes on each plug - good spark and they never seemed to foul...
Old Jul 28, 2004 | 08:41 AM
81ZZ4's Avatar
81ZZ4
I have had the best luck with NGK and ND
Old Jul 28, 2004 | 01:40 PM
Super Stock's Avatar
Super Stock
Lars is right (as usual) Also on my race motors , with the dome height required for 15 - 16 to 1 ratios, if indexed wrong the piston has actually kissed the ground electrode closing it up leaving a dead hole. I have gone through as many as 100 new plugs just to get a couple of useable sets.
To Looking for advice on spark plug selection
