The Autozone here didn't carry any type of additives. The only place I could ever find it was the dealer... who charged a pretty penny for it... ($11)
You'll find the "drain" plug... and I use the term drain loosely.. on the back of the differential towards on the passenger side. I hesitate to call it a drain plug because it's high up on the housing... so as a result, you have to suction the old oil out somehow... unless you have the differential out of the car.
Best of luck.
It's more of a fill plug. Not a horrible job with a suction pump. I have a little pump for the drive unit on my boat. I use that.
Mobil 1, dude. That's all you need. Mobil says you don't need to add friction modifiers and I haven't in mine. It's been running fine for 40,000 miles and changing to it actually cured a clutch chatter problem I had before that.
