Another Turn Signal thread....
Old Jul 29, 2004 | 03:31 PM
Stewart's74's Avatar
Stewart's74
Default Another Turn Signal thread....
My right turn signal doesnt flash. Stays lit continuously. I've checked that the lights work and brake lights work. What should I look for ???The left signal functions flawlessly.
Stewie.
Old Jul 29, 2004 | 03:34 PM
stpman's Avatar
stpman
That's usually a sign of a burnt out bulb
Old Jul 29, 2004 | 03:39 PM
Stewart's74
Thats what I thought but they all light up.
Front and side markers light as well as the rear light/brake light.
Old Jul 29, 2004 | 03:45 PM
stpman's Avatar
stpman
What about the bulb in the dash? Maybe check the grounds
Old Jul 29, 2004 | 03:56 PM
72GACRZR's Avatar
72GACRZR
When you say the blubs work are you looking at them while the turn switch is on, as they should be on but not flashing? If not I would check the front one(it too has two filaments) for busted filament. The rear brake and turn are the same filament and you said that the brake lights worked. If the front blub is good , I would then change out the flasher unit just to save time and trouble checking the system.
To Another Turn Signal thread....
