Powerglide Kickdown Adjustment
Old Jul 29, 2004 | 03:49 PM
Paul L's Avatar
Paul L
Default Powerglide Kickdown Adjustment
I tried this over in C2 but with little in the way of replies. Anyone know how to adjust the carb/transmission kick-down rod?
http://forums.corvetteforum.com/showthread.php?t=872778
Old Jul 30, 2004 | 04:01 PM
72GACRZR's Avatar
72GACRZR
Check the next to last post in this thread from Lars
http://forums.corvetteforum.com/show...light=Kickdown
Old Jul 30, 2004 | 04:34 PM
Paul L's Avatar
Paul L
I do not have a switch or a cable. It is simply a mechanical rod linkage. I adjusted it today to give full transmission rod extension with WOT and choke open. That is the GM procedure. Unfortunately I cannot report results as it is raining.
Old Jul 30, 2004 | 04:47 PM
Fevre's Avatar
Fevre
Paul
With only 2 gears are you sure you aren't in low already?
I sometimes will grab my 4 speed shifter trying to find a 5th gear when my rpm's climb on the e-way.
Old Jul 30, 2004 | 07:59 PM
Paul L's Avatar
Paul L
Sometimes I am tempted to install a TH350 or even a 200R. The Powerglide sure does limit the inherent rev capabilities of a 327. I did not realize that until I bought the C2. That short stroke compared to a 350 makes for quite a free revving engine.
To Powerglide Kickdown Adjustment
