leaks t-tops
Old Jul 30, 2004 | 10:58 PM
wbrad22005's Avatar
wbrad22005
Cruising
Default leaks t-tops
I replaced all the weatherstripping in my 1977 vette. And I can't figure out where the water is coming in thought the t-tops.Help I also put $300.00 of new carpet in it.So you can see why concerned.
Old Jul 30, 2004 | 11:04 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
check your windshield frame
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
if it's dripping down your windshield, the problem may be there more than your T tops...the windshield can leak quite a bit due to rust or old age of the sealant and appear to be the tops....I had that problem once, lucky for me it was old sealant.......
Old Jul 30, 2004 | 11:05 PM
Avette4me's Avatar
Avette4me
dayum corz...you had that too eh..
PRESSURERAT's Avatar
PRESSURERAT
It is damn near impossible to seal up the t-tops on a corvette. I replaced ALL the weatherstripping in a couple of c-3's and could never stop all the water. Nowadays I just keep a cover handy.
Old Jul 30, 2004 | 11:06 PM
Corz's Avatar
Corz
you name it, I broke it
wbrad22005's Avatar
wbrad22005
Cruising
it is not leaking when i drive. it only leaks when left out and it gets rain on and it drips right on my drivers side seat
Old Jul 30, 2004 | 11:08 PM
Corz's Avatar
Corz
yeah, thats your windshield frame. guaranteed the sealant dryrotted.
or the frame itself is rotting away
Old Jul 30, 2004 | 11:16 PM
wbrad22005's Avatar
wbrad22005
Cruising
i even got the trusty hose and sprayed it on top of the car and it don't leak but as soon as i think it is fixed i drive it to work or store and if it rains my seat get wet
Old Jul 31, 2004 | 03:07 AM
Pete76Shark's Avatar
Pete76Shark
Default Leaking T Top
A few years back I replaced the rubber around my tops and doors also. To fix the leaks I removed every piece of trim from around the windshield and the t-tops (the plastic trim inside). Then I did the hose trick with my wife outside and me inside the car. It was a pain but I did find and fix every leak.
The t-tops are adjusted by adding or removing spacers to the "pins" that line up with the center rail. If you remove the plastic trim from the t-top you will see what I mean. This was one of my problems, spacers were setup for the old worn out weatherstripping.
Old Jul 31, 2004 | 03:40 AM
camaroneil's Avatar
camaroneil
my t-tops do not leak,,,,,, i must be one of the chosen few,
but the screen does,
i stuck a bit of wire in the passenger side of the widscreen and the sealer just popped out,
squeezed some sealer in the edge and it leaks a lot less,
just haven't got the ***** to take the screen out and do it properly,
neil
Old Jul 31, 2004 | 07:53 AM
Vette-4-Life's Avatar
Vette-4-Life
My t-tops don't leak either. I replaced all the weather stripping and would have water drip down on the front of the drivers seat and passenger seat.
I removed the trim that goes along the top of the windshield and with the garage closed, and as dark as possible, had the girlfriend shine a flash light all around the weather stripping. I could see light coming in where the chrome t-top cover piece meets the chrome windshield pillar piece on both sides. Applied a fine bead of clear silicone and no more leaks.
Old Jul 31, 2004 | 09:33 AM
Avette4me's Avatar
Avette4me
neil
I'm not sure how things work over there, but I just called a mobile windshield repair, about $80.00 and an hour later they had pulled it off, resealed, and reinstalled it..
without the proper tools, I would be very hesitant to try it as it appears thet the windshiels would be very easy to break......
Old Jul 31, 2004 | 09:52 AM
Paul 77's Avatar
Paul 77
Same problem here, I Put in all new weather stripping in my 77 and leaks gallore. I have roof leaks and the windows leak just as bad as they ever did. I guess i just have to adjust a few things...
To leaks t-tops
