Tire Pressure?
Old Jul 31, 2004 | 09:29 AM
ClockworkOrange's Avatar
ClockworkOrange
Default Tire Pressure?
Hi Guys
I set the tire pressure to 20 psi as it says on the door post.
Is that OK for modern tires?
I am running P255-60-15's on stock wheels
Old Jul 31, 2004 | 09:36 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
for modern tires - 30 - 35 psi is usually the normal pressure range.. 20 psi is too low!
Old Jul 31, 2004 | 11:29 AM
75 Hot One's Avatar
75 Hot One
That original 20 psi must have been a mistake from the start. The cars were running around with a bulge on the bottom like they were half flat. If you're now running radials, you should use about 35 psi and monitor the wear pattern to see if adjustment is necessary.
Old Jul 31, 2004 | 12:19 PM
Paul L's Avatar
Paul L
I have a nice clean/even wear pattern with 32psi cold. That will go to 35-36 with the heat this time of year.
Old Jul 31, 2004 | 01:26 PM
aharte's Avatar
aharte
I use 38 psi cold on 255/50-16 tires. So 30-35 is probably good for your thicker sidewalls.
Old Jul 31, 2004 | 03:36 PM
ltlevil's Avatar
ltlevil
Look at the side of the tire for the manuf. recommended pressure.
To Tire Pressure?
