Dipstick leaking
Old Aug 1, 2004 | 12:28 PM
Steve Straus's Avatar
Steve Straus
Default Dipstick leaking
Has anyone had a dipstick leak on a bigblock? I have a Milodon pan and a lokar dipstick. The part of the dipstick that goes into the pan is a billet piece with 2 o-rings.
I'd like to avoid RTVing the thing, mainly because I don't want any slopping down into the pan.
Has anyone else experienced this?
Old Aug 1, 2004 | 07:12 PM
Steve Straus
nobody loves me
Old Aug 1, 2004 | 07:19 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Hi Steve. Wish I had some experience there. That would mean my 454 is running.
I'm using the Moroso racing pan and had to tap the snout of the pan to accept the screw-in base of Moroso's custom dipstick. It held the base & tube together via compression fitting.
I've heard of guys using silicone to seal, and I think the 350 from my '89 Sub just had sealant at the junction.
You've certainly had your share of oil leaks.
Old Aug 1, 2004 | 10:42 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
One of the most common causes of oil leaking past the dipstick is excess crankcase pressure which forces the oil past the weakest seal. A defective (or incorrect) pcv valve or excessive blowby are a couple of possible suspects.
Old Aug 1, 2004 | 10:43 PM
Steve Straus
Thanks Len, yeah I've had my share of leaks, but I think that's over as soon as I get this one nailed. Tell me more about this dipstick with a compression fitting.
Old Aug 1, 2004 | 10:49 PM
Steve Straus
Vetterodder, I don't really have much blowby, but I think my pcv is sucking oil. I just ordered a baffled grommit, maybe that'll help with that. The builder put a high volume oil pump in the engine when it probably doesn't need it. What else could cause excessive crankcase pressure? Would a PCV sucking oil do it?
Old Aug 2, 2004 | 07:05 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Here's a pic, a little blurry though.
I got the dipstick from Sumitt, it's a Moroso, supposed to match the pan. What they don't tell you is that you have to tap the oil pan dipstick snout. The dipstick comes with a screw in base for the dipstick. Then a 3/8 (I think) compression fitting and cap nut slides over the dipstick. Slide the dipstick. cap & compression fitting into dipstick snout & tighten. Just thought of this though, you'll create metal shavings when you tap the pan.
See you're from WV, how close to Pittsburgh & Western Pa?
Old Aug 2, 2004 | 09:15 AM
Steve Straus
Yep, I'd have to remove the pan to do that, but if I have too much crankcase pressure I need to resolve that first. The dipstick that I'm running has a double o-ring seal, so that shouldn't leak under normal circumstances methinks.
I moved to WV about a year ago from the Northern VA area. I'm about 60 miles from the DC area. I'm about 1.5 hours from Carlisle.
Old Aug 2, 2004 | 05:57 PM
Tiredol74's Avatar
Tiredol74
You may wanna look into crankcase evacuation system for your
motor if haven't already. Your problem could very well be your high volume oil pump and/or low vacuum. Been lotsa discussion on CF. Do a search.
To Dipstick leaking
