Hood Clearance Issues...
Old Aug 1, 2004 | 08:48 PM
DollaGreen's Avatar
DollaGreen
Default Hood Clearance Issues...
I thought I was done worring about this but it cropped up again today. My stock hood barely clears the top of my air cleaner (I have a drop base edlebrock to make it fit). It seems that under hard acceleration the engine twists enough to hit the hood. I noticed some semi serious scratches where the air cleaner nut hits the hood. Here are my questions.
1)I had a new motor and motor mounts put in less than 2 yrs ago, how much twist is normal, could I have a broken or worn motor mount already. (side note: my shifter moves a lot as well, but I was told that this was normal, since the hurst is mounted right to the tranny)
2)What am I going to break. The scratches in the hood are not really big deal to me, and I am not gunning it all the time, but what could I screw up motor wise, just the air cleaner or could I damage the carb/intake etc.
3)I plan on paint in the not to distant future and will probably go with an higher-rise hood at that point. When you get one of these hoods from ecklers etc. what is all involved in getting the fit right. Are they pretty much bolt on, or is there some work involved.
I could really do without spending the dough on a new hood, but I think my options are limited.
Old Aug 1, 2004 | 09:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default clearance?
I am running a performer manifold, and an Edlebrock Performer series Quadrajet. I have a 3.5" tall air cleaner and it fits fine. Drop base is mandatory of course.
I have a custom wingnut that I use in shows that is about 3/8 inch high and shaped like a triangle. If I drive with that on, it puts a triangluar dent in the underhood insulation. So I keep a normal wingnut on it and have no issues.
Motor mount breakage is easy to see though! Especially the way the hoods open on these cars. Just leave the hood up and see if the engine walks when you accelerate w/foot on the brakes. If it lifts up at all, the mount is bad.
I said 'lifts up.' so don't mistake normal torque for lifting.
Old Aug 2, 2004 | 11:52 AM
DollaGreen's Avatar
DollaGreen
ttt
Old Aug 2, 2004 | 01:42 PM
machineg's Avatar
machineg
Default Hood clearance
I have a new 71 with base motor 350. I put a preformer edelbrock carb and intake. I had to put a 2" filter with drop down base for my hood to clear. it sucks. I would prefer to have a 3" air cleaner. but the hoo will not close. Why does yours fit and mine doesn't.
Old Aug 2, 2004 | 01:49 PM
DollaGreen's Avatar
DollaGreen
mine is a 2in and a drop base...it closes, but actually being able to run this setup is the question? Pauls is a 76...maybe the hood is different?
Old Aug 2, 2004 | 02:37 PM
machineg's Avatar
machineg
Default Good luck
Good luck
Old Aug 2, 2004 | 02:49 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Solid motor mounts will drop your engine about 3/4" to 1". That may be all you need to clear the cleaner.
Old Aug 2, 2004 | 04:09 PM
crf311's Avatar
crf311
I changed my hood to the L88 for 2 reasons. 1) More clearance. 2) Elimanation of the wiper door. Best Mod I did to the car. Changes the whole look for the better.
Old Aug 2, 2004 | 04:18 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
The engine should not twist very much with good, new motor mount. I swear I thougt the engine would would pop out of the car with my distroyed mounts. Maybe your mounts are defective????
Old Aug 2, 2004 | 04:54 PM
DollaGreen's Avatar
DollaGreen
I found out I do have a broken motor mount on the driver side...only about 3k on the motor and mount. I dont beat it very often either. Is that strange? So what type of mounts do you suggest? What are the types and pros/cons. Thanks for the feedback!
Old Aug 2, 2004 | 06:59 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
That's a awsome looking '69
Old Aug 2, 2004 | 07:41 PM
Michel B's Avatar
Michel B
I replaced mine with locking mounts, I thougt this would prevent any damage to my fan shroud should they fail, the locking feature prevent the engine to climb out of the car. shop around on the net, they are wildly available allmost everywhere, and not expensive. The poly ones also catched my attention, maybe someone here can give you some feed back.....
To Hood Clearance Issues...
