heater control?
Old Aug 3, 2004 | 10:15 AM
terrible_buddhist's Avatar
terrible_buddhist
Default heater control?
Has anyone rebuilt theirs? How was it and what kit did you use?
Old Aug 3, 2004 | 05:00 PM
Disco_Mike's Avatar
Disco_Mike
mine works fine except for the vacuum switch.
looking forward to replies.
Old Aug 3, 2004 | 05:40 PM
Wrencher's Avatar
Wrencher
Mine was inoperative when I got it. After I fixed the electrical (blower motor frozen, bad hi-blower relay, disconnected ground) it only blew out the defroster vents. I checked all the vacuum lines using the assembly manual and found my supply line from the engine burned(!) through. Hooked it up and found the vacuum switch leaking badly. Put a used switch in it (bought a whole control assembly cheap) and it wasn't much better, still leaked enough vacuum to be non-op. Finally got a tip to take it out, GENTLY pry it apart slightly and used Vaseline to grease the gap a bit. That did it. It now works perfect.
Hans
To heater control?
