PCV Valve Questions..Please Help
Old Aug 3, 2004 | 04:37 PM
billlambeer's Avatar
billlambeer
Default PCV Valve Questions..Please Help
So im looking back at all these pcv questions and it seems as though lots of people are sayin different things. I just was wondering if this is what many of you guys were talking about.
I am gonna run Moroso Aluminum Valve covers(anodized), and then if i put one of these in one side:
http://store.summitracing.com/partde...N=120%20303654
And then one of these in the other side:
http://store.summitracing.com/partde...N=120%20304577
Is this how everything is supposed to work for the breathing and what not??
Thanks so much for your help!!
Matt
Old Aug 3, 2004 | 04:40 PM
Fevre's Avatar
Fevre
Those are both breathers so you will have no pcv (Postive Crankcase Ventilation) valve. Although not needed it helps to suck all the 'bad' air out of the crankcase and eliminate possible fumes from coming out of the breathers when you are standing still and idling.
Old Aug 3, 2004 | 05:09 PM
billlambeer
so eventhough the first one says a pcv setup, its not a true pcv? sorry..new to this type stuff..
Old Aug 3, 2004 | 05:17 PM
Fevre's Avatar
Fevre
It is a breather to used with a pcv set up. You need either of those breathers on one side and a pcv valve on the other side that has line running to your carb. The carb will draw the air through the breather across the eng and out the pcv valve. Not 100% needed but it does keep smoke from rolling out from under the hood and a nasty smell when sitting and idling.
Old Aug 3, 2004 | 05:36 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by Fevre
: Not 100% needed but it does keep smoke from rolling out from under the hood and a nasty smell when sitting and idling.
I prolly need a couple then...
Old Aug 3, 2004 | 05:38 PM
Fevre's Avatar
Fevre
I said out of the hood not out of your a$$.
Old Aug 3, 2004 | 05:51 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Yeah, those are both breathers, and can be used on one side with a pcv valve on the other side.
Some companies make a breather for one side, and a breather / PCV for the other. It looks like a breather, but has a connection and valve inside to make it a PCV valve.
Billet Specialties breathers fit valve covers with a 1.22 in. diameter hole, and you can take your pick of either regular breathers or those with a standard, replaceable PCV valve.
Old Aug 3, 2004 | 06:03 PM
Avette4me's Avatar
Avette4me
To PCV Valve Questions..Please Help
