Radiator Scale Question
Old Aug 4, 2004 | 05:54 PM
johnb74's Avatar
johnb74
Default Radiator Scale Question
Hi all,
I just had my radiator boiled three years ago and already have visable scale deposits when I recently opened the cap. I remember reading an old post about using a cup of CLR to flush the radiator and wonder what others have used. I also wonder whether CLR could damage block gaskets? Any thoughts!
Old Aug 4, 2004 | 07:13 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I've always used the 2-part DuPont stuff. Cleaner, then a neutralizer. The stuff is pretty aggressive, but even the CLR should be neutralized after use. I think the key is prevention by changing the coolant once a year.
Old Aug 4, 2004 | 11:13 PM
johnb74's Avatar
johnb74
Any more thoughts!
Old Aug 5, 2004 | 12:15 AM
martinsw's Avatar
martinsw
I have cleaned mine, still running hot, thinking of going with an aluminum radiator next .....
Old Aug 5, 2004 | 02:27 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
scale comes from using tap (hard) water in your coolant mix. If you use distilled water you won't get this problem. Don't go for "soft" water from a home water softener as that still has minerals in it. Get distilled water from the store and use that.
To Radiator Scale Question
