What determines shift point on TH400?
Old Aug 4, 2004 | 08:05 PM
T-Top Tom 1
Guest
Posts: n/a
Default What determines shift point on TH400?
On a 1974 TH400 what determines shift point on WOT? Mine is shifting around 4000 rpm. What needs changed? Thanks for any info.
Old Aug 4, 2004 | 09:38 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the governor controls WOT shifts. you can drill holes in the weights and/or change the springs
Old Aug 4, 2004 | 11:43 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I could be wrong, but I thought the governer was kind of a "fail safe" that would cause an upshift before the engine would over-rev (I thought usually around 5500 RPM) and the modulator is what is supposed to cause an upshift based on vacuum. It does sound like your governer is having problems though.
Old Aug 5, 2004 | 01:21 AM
enforcer's Avatar
enforcer
B and M used to sell a kit to changed the weights and or springs in the govenor. It was real easy to do and got my shifts where I wanted them. You might find a similiar kit elsewhere.
Old Aug 5, 2004 | 02:28 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
They still do.
Old Aug 5, 2004 | 06:06 AM
Larry B.'s Avatar
Larry B.
If the kickdown solenoid doesn't work, somehow it will shift earlier than it does on the detent. I am not sure why but I have had a couple of th400's do that.
Old Aug 5, 2004 | 07:27 AM
NHvette's Avatar
NHvette
Matt Gruber had a nice post on this - specifically the governor
calibration kit/install/adjustments. I searched for it - but not in
the archives anymore. Maybe it will be resurrected later.
I remember he cut a hole in the trans tunnel and put a plate
over it, so the governor could be removed from inside the car.
Old Aug 5, 2004 | 09:57 AM
Matt Gruber's Avatar
Matt Gruber
just check my homepage
To What determines shift point on TH400?
