Tuning a Holley 750 DP
Here's what we stumbled across.
With the motor up to temp and running he set all four corner idle screws with a vacuum gauge. My solid Crane cam is 238/248 so getting a solid 13 at idle is pretty good @900 rpm. 14 degrees initial advance and 38 total @3000 or so rpm. I have about 10.6 compression and iron heads double hump ported heads.
Everybody on here was thinking Pink squirter cam. So with the motor running he disconnected the gas petal linkage. When you open the throttle slow. NO SQuirt at first. It didn't matter how you adjusted the pump arm.
So he took off the cam follower arm that moves the squirter. We just put it in a vice and made it more straight. The car is like new. What a moron, "ME" something so simple. From years of use the arm got bent maybe even from bottoming out at the end of the stroke.
So he also bent his arm on his demon and now were both happy!
He was able to get the Vacuum to @13 inches max at 900 rpm with my 238/248 Crane solid cam 114 LC.
We got to looking at my squirters with the pink cam. He noticed that II didn't have instant squirt no matter how he adjusted the pump arm. So we pulled of the arm that follows the cam and bent it opener. So it would ride on the cam.
It's probably got bent from the pump arms bottoming out or just to many times massing the gas to the floor.
At any rate it's a new car again. It hasn't run this good in years.
This is why I went to FI on the BBs
Wound up, for now, I am running ~8 deg intitial with additional 10-11 deg advanced using manifold vac at idle. There is ~25 deg mechanical advance that was totally in at about 2800 rpm. Lars' post advised 18 deg at idle and to use manifold vac adv, ....was the 18 measured with or without vac advance connected??? I interpreted it with? Anyway, It's on the road for now
Bullshark
