Engine stumble with light pedal action - HELP!
Old Aug 9, 2004 | 11:30 AM
73'Vette's Avatar
73'Vette
Default Engine stumble with light pedal action - HELP!
Ok, here is the problem. I get on the gas, and the engine runs and pulls fine. But the second I get into a good cruise and am barely pushing the gas to keep a constant speed, I get a bucking action. It happens at any speed, but only when I am barely pushing the pedal. It's like the engine is either cutting in and out or surging. It's annoying the hell out of me. I read this thread - http://forums.corvetteforum.com/showthread.php?t=879769 - and I wish I could try some of the above solutions, but I'm using an Edelbrock 600 Performer. Any ideas for a solution using this type of carb?
Old Aug 9, 2004 | 11:40 AM
Bobchad's Avatar
Bobchad
Have you done anything to your distributor in regards to advance? This can be a sign of too much combined vacuum and mechanical advance.
Old Aug 9, 2004 | 11:43 AM
gkull's Avatar
gkull
The Edelbrock carbs are easy to tune. How familiar are you with changing rods/jet/springs?
Old Aug 9, 2004 | 11:53 AM
73'Vette's Avatar
73'Vette
Nope. The engine was rebuilt by the prior owner, and I haven't done anything to the distributor yet. I got it running so I could get it to the exhaust shop, and now to the paint shop, and I haven't had a chance to do any fine tuning yet. I purchased a Craftsman advance induction timing light, but I only used it to set initial timing so far. When it comes back from the paint shop, I guess I'll have to try and set the total advance.
I've never done it, but I hear it isn't hard, and I'm willing to learn. Any tips?
Old Aug 9, 2004 | 12:02 PM
Bobchad's Avatar
Bobchad
Try disconnecting the vacuum advance and see if you have the same problem.
Old Aug 9, 2004 | 12:05 PM
Bobchad's Avatar
Bobchad
Try disconnecting the vacuum advance for a short test run and see if you have the same problem.
Old Aug 9, 2004 | 12:06 PM
gkull's Avatar
gkull
First thing if you don't have the book - down load it off their site.
Ensure that your vacuum advance is to the ported connection on the carb - not full vacuum.
The idea behind them is simple. You have a two step rod that goes up and down inside the jet with the amount of engine vacuum. The rod is a restriction to flow.
High vacuum like cruise down the freeway the rod is down so the thick part is restricting fuel leaning out the mixture for best gas mileage.
When you push on the gas vacuum goes away the rod lifts to the smaller diameter step on the rod making the mixture richer for power.
Changing the rod spring determines how fast the rod moves with changes in engine vacuum.
They are a wonderful carb and I used them for over 10 years and tune friend's Edelbrocks even today
Old Aug 9, 2004 | 12:56 PM
73'Vette's Avatar
73'Vette
I'll have to try that when it comes back from the paint shop.
It is connected to the passenger side, which I'm pretty sure is the ported side.
Is this all I need to do the carb tuning?
http://store.summitracing.com/partde...25135%20300585
For only 5 bucks, hopefully someone local has it.
Old Aug 9, 2004 | 06:25 PM
The Dude's Avatar
The Dude
IF your timing is OK:
My first thought was that your primary circuit is too lean at cruise. Since you have one of those Edelbrock Carter AFB clones, you'll have to get the procedure for swapping out rods and jets elsewhere.
Plenty of AFB folks around here, though. Good luck.
Old Aug 9, 2004 | 11:23 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
If you haven't checked your timing there's no way to know (for you or for us) if it's the problem or not.
To Engine stumble with light pedal action - HELP!
