TRW specs?
Old Aug 9, 2004 | 08:43 PM
Chris69's Avatar
Chris69
Default TRW specs?
Anyone have the resources to look up a TRW piston? It's a 400NP 30. I'm interested in the amount of dish these have. I've looked around and can't seem to find a thing on them. Tnx!
Old Aug 10, 2004 | 01:10 PM
adam's Avatar
adam
You can try calling Summit Racing 1-330-630- (maybe 0246)
need to use technical number (non 800)
I was looking for the weight of the H631CP 030 pistons. They had the
weight 567g, but didn't have the weight of the pin.
I couldn't find the info on the web either...
Keith Black pistons (www.kb-silvolite.com) have all their specs on the web.
The HB231 piston for example listed at 485g with a 102g pin.
Quite a weight difference...
Good luck
Old Aug 10, 2004 | 03:47 PM
Ironcross's Avatar
Ironcross
What I found is a H400P-30, .025 down, flat with 4 valve reliefs.
Old Aug 11, 2004 | 06:04 PM
Chris69's Avatar
Chris69
Tnx for the info. Not so sure the H400P-30 is the same thing, but that's the closest number so far. I'll check with Summit as well to see if they can look up the 400NP-30. I'm trying to get as accurate as possible for selection of heads to raise my compression to +/- 9.5:1. Presently have stock 76cc heads and hoping 64cc will do the trick.
Old Aug 11, 2004 | 06:11 PM
PRESSURERAT's Avatar
PRESSURERAT
how bout this one?
http://store.summitracing.com/partde...4922410 301507
Old Aug 11, 2004 | 08:53 PM
Chris69's Avatar
Chris69
Originally Posted by PRESSURERAT
That's got to be it. Tnx!!
Now, how am I going to transfer the .160" depth to cc? Use some guesstimates for gasket specs, deck height, etc?
To TRW specs?
