need help with rear bearings
Old Aug 11, 2004 | 01:06 PM
79-L-82's Avatar
79-L-82
Sorry to sound stupid, but;
are you folks talking about doing all the work yourself or just reinstalling rebuilt ones from a vendor?
Mine needs rear bearings and I was going to remove them send them for rebuild and put them back on.
How much work is that?
I'm pretty good with a wrench, but; I don't have a lot of spare time.
I am definitely not going to press the bearings, etc. myself.
Old Aug 11, 2004 | 01:15 PM
Tom454's Avatar
Tom454
We're discussing the process involved in actually doing the dis-assembly, fitting, re-assembly... wether it be the owner or a shop.
Edit- removal and re-installation of the arms is not always "easy" per se, but most mechanically inclined guys can handle it.
Cars from the snow(salt) belt are the most difficult because of the rust involved.
Removing and re-installing the through bolt at the front of the arms is usually the most difficult part.
To remove the factory struts (lower shock support) you need another special tool (or method) to avoid breaking the ears off the spindle support.
Old Aug 11, 2004 | 01:16 PM
cryzko's Avatar
cryzko
Default umm
anyone near detroit that wants to do it for me......... i'll pay a few bucks but places i called want 150-300 to do it...... anyone know of any shops near detroit that can do it?
cryzko
Old Aug 11, 2004 | 05:39 PM
mandm1200's Avatar
mandm1200
cryzko
I am kind of in the same boat. I do not know of any garages that work on Vette's. The only place that comes to mind is the Chevy garage. I wonder it they have the tools and the knowledge to do it. The job does not seem overly technical but does require the patience to get the right clearance. Before I would pay $300, I just get replacements already done and sell the old ones. The problem as I see it is that I don't want to spend the money for tools that I may never use again, but I may have to bite the bullet and buy them; and then rent them out to other members.
Old Aug 11, 2004 | 07:21 PM
cryzko's Avatar
cryzko
Default umm
yeah, i should have just bought the whole new bearing assembly already done. it would have saved me a few bucks by now and a couple temper tantrums in the garage...... have to breath.... in thru the nose out thru the mouth...
cryzko
Old Aug 11, 2004 | 07:45 PM
cryzko's Avatar
cryzko
Default umm
the spindle setup tool is over 100 bucks....damn, i should just take it somewhere and have them do it...... i already tossed in more money in the rear end than i wanted to........
cryzko
Old Aug 11, 2004 | 10:30 PM
cryzko's Avatar
cryzko
Default ahh
think i got it...... i figured a way to measure for the size shim i needed..... i have the outer bearing on the spindle pressed in and both race ways in the support.... i then put the spindle,spacer and a shim in the support and measured from the top of the shim to the bottom of the race for the inner....... i had about 1/16th of an inch of clearance left with the shim in...... i figure once it all get tightened down, that number will shrink some...... i used the bigger sized shims so hopefully it'll all work out................. one last thing, what kind of grease should i use for the bearings and how much should i fill it up with?
cryzko
Old Aug 12, 2004 | 02:33 PM
stingray4me's Avatar
stingray4me
I didn't use any new shims. I must of been lucky too. I did mine several years ago & haven't had any problems. I used a spindle knocker with a mini sledge to knock it out.
