Differential Fluid Change
Old Aug 12, 2004 | 12:46 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Differential Fluid Change
I am about to change the fluid in my differential and have heard that I need to replace the fluid (with new additive) then drive the car making very tight turns. Redrain the fluid and replace again.
Does everyone recommend this process?
Old Aug 12, 2004 | 01:00 PM
Nick-75Roadster's Avatar
Nick-75Roadster
I agree that you need to use posi additive with the new fluid (I like the synthetics best) and you should perform a series of tight turns in both directions, say in a parking lot, to help work the addidtive in. I don't believe you need to drain and refill afterwards again, however.
Old Aug 12, 2004 | 01:04 PM
Fevre's Avatar
Fevre
Ain't like washing your hair;, lather, rinse, repeat.
Just change it and do the figures 8's and you're done.
Old Aug 12, 2004 | 01:25 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Yep, what they said. No need to drain and re-fill again. I don't use the additive when using Mobil 1 but others do. Definitely use the additive if using normal oil.
Old Aug 13, 2004 | 05:48 PM
PureSilver's Avatar
PureSilver
The double change is if you have been having chatter in the Positraction clutches.
Old Aug 13, 2004 | 08:15 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
First time I heard of changing it twice, I was getting some vibration and noise in the rear so I just changed mine last weekend and it is much better but there is still a little chatter left I wonder if I should change it again ?
To Differential Fluid Change
