Holley fuel pump question
Old Aug 14, 2004 | 08:45 AM
viperjesse's Avatar
viperjesse
Default Holley fuel pump question
Ok - stupid question. There are 2 ports on my Holley mechanical fuel pump part no. 12-327-11, one thast is bossed out and one that is flush with the pump body. Which is in and which is out?
I don't have the instructions that must have come with it.
JZ
Old Aug 14, 2004 | 09:43 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This looks like the one I have. I used the upper port as the outlet.
Old Aug 14, 2004 | 07:51 PM
viperjesse's Avatar
viperjesse
Thanks Eddie but my ports are in-line around the diameter of the pump body. The one port is in a standoff about 1/2 out from the body and the other port is tapped right into the pump body.
Old Aug 14, 2004 | 08:42 PM
Eddie 70's Avatar
Eddie 70
This is the image that summit racing has for the pump so that is what I was basing my reply on. Sorry.
Hopefully someone else will chime in for you.
To Holley fuel pump question
