Msd
Old Aug 14, 2004 | 08:13 PM
Motor City Vette's Avatar
Motor City Vette
Default Msd
Does anyone have the MSD setup in an early C3? If so, what are your thoughts on it...how hard was it to install, etc.? I think I might want to get rid of my points and I've heard quite a bit of positive reviews of the MSD.
Thanks.
Old Aug 14, 2004 | 08:39 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Do you mean the 6A or 6AL, or the distributor or both together? I have the 6A and using a Pertronics under the cap. The 6A box did make a difference with starts and general driving.
Old Aug 14, 2004 | 09:39 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Running the MSD 6AL box, billet distributor, coil and wires. Main reason I went with the 6AL as well as others, was the rev limiter feature. Been happy with it for 4+ years now.
Old Aug 14, 2004 | 09:50 PM
Gordonm's Avatar
Gordonm
I have the Crane HI6 box on mine. Very similar to the MSD box but no pills for the rev limiter. Just 2 rotary dials for the rev limiter. Been very happy with it. I am using the stock dist and a MSD coil and the Crane box. It performs well to 7000+ rpm. Starts better and idles better with this setup.
Old Aug 14, 2004 | 09:53 PM
lostpatrolman's Avatar
lostpatrolman
I have had no real problems with my MSD. When installed it was wired to something that wasnt getting a full 12volt so the engine ran poorly and eventually stalled at a stop. Since that was corrected it ran fine. I can not comment on teh drivability vs the points though, since I installed it after the engine rebuild. I have read that the revlimiter isnt so good on the msds though. Can sometimes be a few hundred rpm off. Mine is dead set at 6k rpm though, which is where it is supposed to be. The msd tach drive distributor has a grease fitting so the cross drive can be lubed, that is pretty cool. I know that when i went from points to a factory electronic sparkbox on my 69 mustang with a 302 that I instantly got 2mpg better gas mileage.
Old Aug 14, 2004 | 10:01 PM
gdh's Avatar
gdh
MSD 6AL with Petronix II, very happy with the results after 3 years. I was told by MSD that the plug gap should be btn .45 & .55 instead of the stock @ .35 although I didn't change the gap I will try it on my next tuneup.
Old Aug 14, 2004 | 11:21 PM
crf311's Avatar
crf311
I have the complete msd set up . box. dist & coil. This was the best modification I made to my vette.
To Msd
