rear end noise when turning from stop
Old Aug 16, 2004 | 07:53 AM
76REDSTINGER's Avatar
76REDSTINGER
Default rear end noise when turning from stop
possible possi noise?
terrible noise when accelerating from stop and turning.
sounds awful
use possi add and Amsoil gear lube.......
suggestions
other possible culprits?
all new rear, joints, bearings ....ect
R.
Old Aug 16, 2004 | 07:58 AM
BatManFire's Avatar
BatManFire
I bet it is what you don't want to hear. Get ready for a new rear-end. On the brighter side you can get the gearing you really want. I hope mine goes bad before I put it up for the winter. I need a 373 rear gear.
Old Aug 16, 2004 | 10:27 AM
76REDSTINGER
why do you say that?
dont think its the possi?
diff was out on shelf for a year dry, have 60 miles on it from install
thanks
R.
Old Aug 16, 2004 | 11:00 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Who rebuilt it. Just b/c it was rebuilt doesn't mean they put new clutches in it. On the bright side you maybe do not have the fluid mixed in well enough. Did you do figure 8's in a parking lot. Some times you'll need to do that before the noise will go away.
Old Aug 16, 2004 | 12:33 PM
76REDSTINGER
thanks
im going to put in another bottle of add and do that figure 8 thing for awhile tonight after work
its really loud/annoying
Old Aug 16, 2004 | 12:53 PM
Van Steel's Avatar
Van Steel
Also it's best if you put the additive in 1st Good Luck w/it
To rear end noise when turning from stop
