Carb, timing, acceleration issues
Old Aug 16, 2004 | 04:40 PM
thevetterisbetter's Avatar
thevetterisbetter
Default Carb, timing, acceleration issues
Okay. I think I have my carb leaned out pretty good. I am not eating gas as much as I was. I also think my timing is down and the car idles at 900 RPMs when warm. It still has a hesitation or bog if I floor it, esp. at higher speeds in 3rd or 4th gear. If I am in 1st or 2nd and floor it the tires get all greasy and the car really goes. Am I too lean or is the timing still off? I put a lower rated spring in (3-4 Hg) my power piston pump. The jets are stock for a 1974 L-82 4 speed as are the needles.
Any and all advice greatly appreciated.
Old Aug 17, 2004 | 11:20 AM
thevetterisbetter
Anyone?
Old Aug 17, 2004 | 12:10 PM
stingraymaniac's Avatar
stingraymaniac
how does your plugs look?
cant you get an lower idle??
i have mine at 600rpm
before i had my carb restored with all new part i couldnt get the car too idle under 1000 rpms
What carb do you have?
sounds like you are a little lean on the secondary.
Old Aug 17, 2004 | 12:37 PM
Boofers's Avatar
Boofers
Are you are saying you get a hesitaion when you go from cruise to WOT? If so maybe you have a vacuum advance problem.
Old Aug 17, 2004 | 02:39 PM
thevetterisbetter
That's exactly what is happening. It doesn't happen so much in 1st and 2nd though. What kind of vacuum advance problem?
Old Aug 17, 2004 | 06:38 PM
Boofers's Avatar
Boofers
It may seem as if the gear you are in plays a part but I imagine it probably has more to do with a combination of engine RPM and how much load there is on the engine (vacuum). More load = less vacuum. When you go from cruise to WOT your engine goes from max vacuum to min vacuum. Now that I have thought about it your most likely culprit is an improperly set secondary air valve adjustment. Read this post, especially what is written by Lars (QJet guru). http://forums.corvetteforum.com/show...ight=secondary
More great QJet info:
http://www.corvettefaq.com/c3/QJetTuningPaper.doc
If that isn't it then verify your timing, often times ignition problems and carb problems give the same symptoms.
https://www.corvetteforum.com/techti...=109&TopicID=3
https://www.corvetteforum.com/techti...=115&TopicID=3
Good Luck
To Carb, timing, acceleration issues
