Widest wheel with offset trailing arms?
Old Aug 17, 2004 | 02:30 PM
Red73's Avatar
Red73
Default Widest wheel with offset trailing arms?
What is the the widest 17" rear wheel & tire combination that I can put on my vette with offset trailing arms and keeping the tires within the fenders? Also, what wheel offset will work? info with pics would help. Thanks, Rod
Old Aug 17, 2004 | 03:21 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
It's not the absolute widest but it fits and looks nice. 285/40/17 9" Rim 5" Backspacing. Sorry no pics.
Old Aug 17, 2004 | 03:52 PM
WA 2 FST's Avatar
WA 2 FST
I'm running 285/40-17s with 9.5" wide wheels and 4.75" BS w/ my offset TAs. 5" would have been very close to the frame and the VBP 'glass spring. Some guys run this with no problems. I'm glad I did it the way I did, though.
Old Aug 17, 2004 | 05:45 PM
gkull's Avatar
gkull
Rod - 5 inch BS is the most, with OS TA's You also have to have Smart Struts or the equivolent so you have minimal camber changes with the verticle travel of your tires.
The older pictures from Wyoming on my CF home page are 285/40/17s although. I was using 6.5 bs with two inch adapters 4.5 bs equiv
The tire diameter is googd for filling the wheel well. I even kept my sets of 1/2 tread Goodyear Eagle F1 Steel Z-rated
Old Aug 17, 2004 | 07:01 PM
Red73's Avatar
Red73
George, I'm running smart struts. I'm concerned with hitting the spring, does it need to be shorter or cut back with 4.5" or 5" backspacing? Does the sway bar need to be removed? Rod
Old Aug 17, 2004 | 07:38 PM
gkull's Avatar
gkull
Rod. I never had a problem and I have steel springs. Measure your distance to your present side wall & rim. I'll measure mine later and post my space with EQ. 4.5 and 315/35 tires. They do have a side wall bulge that brings them inboard.
I never bought OF T.Arms long ago because when they arrived and I had my car on the rack at a shop I couldn't see what I was really gaining. So I sent them back and bought the HD trailing arms with new spindles........
Old Aug 17, 2004 | 07:43 PM
gkull's Avatar
gkull
I just went out and looked I have an inch or so. Because Centerline rims are not that tall off the bead of the tire and the spring actually goes inside the rim at the 4 O'clock position.
Got to run I'm Late for a 5:00 pm meeting already!
Old Aug 17, 2004 | 08:39 PM
norvalwilhelm's Avatar
norvalwilhelm
I ran 5 inch back spacing with offset trailing arms and yes I cut the spring shorter. It came so close with that backspacing that I was afraid side wall flex would cut the tire.
STEEL SPRINGS ARE EASY TO SHORTEN.
I also ran/run 305's with 5 inch backspacing and it clears the frame fine.
This is a shot of 305 tires with 5 inch offset rims but the lower strut rod is disconnected from the center and is handing down supporting the tire and rim, It is pushed out at the top
Old Aug 18, 2004 | 09:12 AM
Red73's Avatar
Red73
Anyone know how this guy was able to fit 315/35 17s? What size wheel and what back spacing did he use? Did he modify his suspension to accommodate his wheel tire combination?
http://www.vetteweb.com/features/vet_0311_badness/
Old Aug 18, 2004 | 09:44 AM
gkull's Avatar
gkull
Rod, I think that this says it all
quote from the article link you posted.
The suspension was kept stock; staying with the F41 suspension components seemed like the right thing to do, but Kurt did mount the rear suspension using offset trailing arms. With the increased backspacing this combination had to offer, Sikora was able to keep the 315/35R17s Kumhos wrapped around 17-inch Billet Specilities Streamline wheels tucked neatly in the fenderwells. But all this would be for naught if the frame tied itself into a knot thanks to all that torque. To keep this from happening, Kurt boxed in and encapsulated the side rails from the door to the rear wheel.
I have seen IRS Vettes that have been tubbed. The limitation for stuffing big tires under a vette is the wheel well frame rails. This Kurt guy boxed in his own frame rails towards the car center line.
Norval has 15 inch wheels 17 or larger diameter the spring rides inside of the wheel.
Old Aug 18, 2004 | 09:57 AM
Red73's Avatar
Red73
George, I read the article, but was not convienced that he didn't move anything to accommodate the wheel & tire combination. Rod
Old Aug 18, 2004 | 10:30 AM
gkull's Avatar
gkull
Where it says from the door. That includes the trailing arm front pivot point. So he could have even moved them inboard and inch or two each.
IMO - Don't waste your money on 17's The price of 18's isn't that much more.
To Widest wheel with offset trailing arms?
