4sp to 5sp
Old Aug 17, 2004 | 05:55 PM
lthrneck's Avatar
lthrneck
Default 4sp to 5sp
I thought there was a discussion thread on 5sp's for c3's but I can't find it. Anyone recall or have any experience with replacing a 4sp trany with a 5sp. I have a 68 Vette 327 and would like to swap out the 4sp.
thanks in advance.
Old Aug 17, 2004 | 07:07 PM
zwede's Avatar
zwede
Tons of threads and many of us have done it. What in particular would you like to know? I detailed the installation of my Tremec TKO 5-speed on my webpage (see sig).
Old Aug 17, 2004 | 07:29 PM
Gordonm's Avatar
Gordonm
I have done this also. Nice swap. Made the car drivable on the highway without giving up the performance.
Old Aug 17, 2004 | 10:02 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Since Dave hasn't chimed in yet check out ddecart's website http://home.comcast.net/~ddecart/Transmission.html
I am in the prelimanary stages of this conversion as well. I'm actually looking for a transmission at the moment. Also, SIGNGUY and others have done the Keisler conversion kit.
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I am in the process of doing this right now. Tonight I came to the conclusion that the best place to cut the crossmember is inside the exhaust tubes (I am doing this with the body on). I think I could make a 6 inch cut inside the tubes and the trans is only 4.5 wide at that point.
Zwede, I saw a past post of yours when you were doing this and couldn't figure out how to keep from cutting the floor. I still can't figure out how you could cut it without wasting the floor and I think cutting inside the tubes is the answer (the trans tunnel is above). Sure would like to know if anyone has done this.
lthrneck: I would be happy to provide details of how this is done. I have a 68 also and I plan to document this swap. Also, most people consider this the biggest improvement that they have made to thier cars. The old Muncies are noisey with imprecise shifting and run out of gear at 50 mph. A TKO 500 is sweet.
Old Aug 17, 2004 | 10:15 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Got a 5 speed in mine also. I installed mine without cutting the crossmember. It is probably going to make future work on the clutch harder but I don't figure I will have to be in there for a long time.
Old Aug 17, 2004 | 10:30 PM
Cali,68,L-79's Avatar
Cali,68,L-79
matching #'s = no cutting.
Old Aug 17, 2004 | 10:34 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I'm here now! Took a couple of weeks to do the whole thing, but it's in and working flawlessly! Absolutely the best possible thing I could have done to my car.
Woah! Lots of pics to add to that site still! Forgot that i hadn't yet done that!
Old Aug 17, 2004 | 11:58 PM
zwede's Avatar
zwede
I used a regular sawzall and it cut it easily without wasting the floor. I put one little nick in the floor but it is more of a deep scratch than a cut. If you cut inside the exhaust tubes I'm not sure the removable section will be wide enough for the tranny.
Old Aug 18, 2004 | 07:07 AM
Gordonm's Avatar
Gordonm
I also cut my crossmember outside the tubes. I have one small nick in the floor. Barely noticable. I did it with a sawzall on my back. Just have to be very careful when cutting.
Old Aug 18, 2004 | 09:00 AM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Same here. Sawzall, a few different blades, on my back, under the car. Got a few nicks in the floor, but nothing major. Besides, who's going to crawl under there and critique my work?
Old Aug 18, 2004 | 09:12 AM
CGGorman's Avatar
CGGorman
I've got the TKO-600 kit on order from Keisler. Lead time is about 3 MONTHS. If you go that route, you should be forewarned.
Old Aug 18, 2004 | 11:16 AM
lthrneck's Avatar
lthrneck
Default 4sp to 5sp
Thanks guys appreciate it.
Old Aug 18, 2004 | 11:25 AM
burners's Avatar
burners
Cruise-In V Veteran
I did at the Cruise In . Dave, what is the diameter of the front bearing support on the transmission? Did you cut the hole in your aluminum plate with a hole saw?
Old Aug 18, 2004 | 03:01 PM
Ken74Conv's Avatar
Ken74Conv
Eddie,
Is it a big deal making the swap without cutting the cross member? What is the hardest part? I'm planning my work for this winter.
Thanks,
Old Aug 18, 2004 | 03:25 PM
75rag4sp's Avatar
75rag4sp
Default Keisler credability
I have been thinking about the swap for a long time and ran into the Keisler guys out at the Carlisle Mopar show. The system looks like a no-brainer. My question is the credability of the company. They want a $1000 down and a 12 week leadtime. I am very hesitant to let go of that kind of cash and get NOTHING in return for three months. The kit looks pretty simple and its not like there isnt demand sufficient to put a few systems in inventory. Has anyone worked with them...how was your experience. They have unsatisfied customers posting on their own web page...that is a little scary for a company asking for $1000 down payment.
Old Aug 18, 2004 | 04:22 PM
Gordonm's Avatar
Gordonm
I bought mine from a forum member who had the kit and decided on something different so I did not have to wait. As far as them stocking they have sold everything they make. They are growing way faster than they can handle. That is why the lead time is so big. The demand is far more then they can handle. They are adding space and employees but they are so far behind they can't catch up. I have had to deal with them for a few minor things and they have been fine.
As far as cutting the crossmember I debated on this for a while. After looking at it I thought it is going to be wayyy easier with the member out of the way. It is not a big deal to cut it and the install is much easier. The way they want you to do it there is little room to install the clutch bellhousing and trans with it all up there at one time. It can be done but I like to make it easier on myself. I'm glad I did it this way.
To 4sp to 5sp
