82 oil temp sender
Old Aug 17, 2004 | 08:27 PM
Terrys69coupe's Avatar
Terrys69coupe
Default 82 oil temp sender
Hi its been quite awhile but I'm back .I have a question from a guy at work that has a 82 and needs to know where the oil temp sender is located. Any help isn appreciated. Thanks terry
Old Aug 17, 2004 | 09:15 PM
BLU 4ME's Avatar
BLU 4ME
Back of the block on the driver side under the Distrubitor. Should have a off white plastic connector on it
Old Aug 18, 2004 | 03:25 AM
Twin_Turbo's Avatar
Twin_Turbo
That's the oil pressure sender, it's for the ECM and the fuel relay emergency shut off (in case of low or no oil press)
The temp sender is just above the oil filter pad.
Old Aug 18, 2004 | 07:13 AM
Ybnormal's Avatar
Ybnormal
Yes twin is correct, atleast on my 81 it is that way. How I know, when I rebuilt my engine I lost oil pressure, to find out a piece of teflon tape had goten in the oil pressure sending unit on the top back driverside of the block. The temperture sending unit is on the drivers side down by the oil filter.
YBnormal...drive a vette
Old Aug 18, 2004 | 10:31 AM
mooneyd's Avatar
mooneyd
It's right above the oil filter.
Old Aug 18, 2004 | 11:35 AM
adam's Avatar
adam
Don't snap it off trying to remove it - its long ...
I didn't snap off mine, but I also gave up trying to remove it...
These sensors are in so tight that I'm worred that I'll have a
motor with a big hole from them breaking out.
Good luck.
Old Aug 18, 2004 | 12:09 PM
Sean82's Avatar
Sean82
If you ground the sensor should the gauge move?
I am guessing that the gauge would read full.
Old Aug 18, 2004 | 12:11 PM
Twin_Turbo's Avatar
Twin_Turbo
ground the connector on the block (short it), the gauge should read maxxed outside the scale.
Old Aug 18, 2004 | 08:49 PM
Terrys69coupe
Thanks guys I know some one would know.!
To 82 oil temp sender
