QUadrajet # location
Old Aug 17, 2004 | 09:32 PM
ESU's Avatar
ESU
Default QUadrajet # location
Where can I find the model (?) # for a rochester quadrajet, 79 vette?
Old Aug 17, 2004 | 10:40 PM
JB's Avatar
JB
St. Jude Contributor
Do you mean the part number? I don't think Q-jets actually came in different "models," so to speak, though certainly there were design differences from one engine & year to the next. The part number is located on a vertical surface behind the the accelerator cable linkage on the driver's side. Most q-jets will have a part number that begins with 70, as in 7029215, which is the part number for the stock carb for my car. Some carbs won't have the 70 (I've seen carbs with the same part number as mine that only have 29215 on them, for instance). I'm told the 70 stands for the primary jet size.
JB
Old Aug 18, 2004 | 06:58 AM
Fleetwood's Avatar
Fleetwood
A 79 vette should begin with 17059***,the last 3 digits depend on the engine type l48 or l82.or if you have manual or auto.
Neil.
Old Aug 18, 2004 | 07:09 AM
ZR-1 Mark's Avatar
ZR-1 Mark
wwww.corvetteactioncenter.com/specs/1979
This should give you what you seek...
Cya,
Mark B.
Old Aug 18, 2004 | 09:59 AM
lars's Avatar
lars
The Q-Jet model number is located on the driver's side of the carb, in the float bowl, directly above the secondary throttle shaft location. The number is vertical. Carb number for a 79 Vette will be one of the following numbers:
17059203 (CHEV 79 FED VETTE A/C & NON 4-SPD)
17059210 (CHEV 79 VETTE L-82 H.P. NON-A/C AUTO)
17059211 (CHEV 79 VETTE L-82 H.P. A/C & NON 4-SPD)
17059228 (CHEV 79 VETTE L-82 H.P. A/C AUTO)
The number has nothing to do with jet sizing.
You can find all the numbers along with correct jet sizes in my Q-Jet chart. E-mail me if you need a copy (V8FastCars@msn.com).
Old Aug 18, 2004 | 11:20 AM
JB's Avatar
JB
Just echoing what Ray Bizzoco says in the 1969 Stingray Guidebook: "The prefix 70 is thought by the author to represent the 0.070 size of the primary jet. When the primary metering rod in 1975 was reduced in length by 0.080 and given a different taper, the model number had a 1 added in front of the 70."
BTW, as in the quote above, Bizzoco also uses the phrase "model number" interchangeably with "part number" when talking about carbs. That don't seem right to me, but I'll bow to the weight of authority.
JB
Old Aug 18, 2004 | 01:17 PM
lars's Avatar
lars
JB -
Funny how people can become "authorities" with faulty information....
The "70" prefix on the Q-Jet is the number identifier for Rochester Products. Q-Jets manufactured by Carter did not have the "70" prefix. All Rochester-built carbs manufactured up through 1974 are prefixed with "70." In 1975, the Rochester identifier code was changed to "170" on all Rochester carb products - not just the Q-Jets with the different rod length.
1969 Corvette carbs were jetted with #66 and #67 jets on the small blocks and #71 on the big blocks. No production Vettes were ever jetted with #70 jets in 1969... I think Ray is a little off in his conclusions...
You are correct: The number on the carb is the part number - not the model number. The "Model Number" on the early carbs is 4MV, and M4M on the 1975 + carbs. Model number and part number is not the same, although many people (including myself) will often interchange the two terms incorrectly.
To QUadrajet # location
