What's wrong with our brakes???
GENE
Also, the floating 2piston caliper design does not have the clamping force of the fixed 4 piston and the floating calipers have problems with the slider pins and all. It's just a cheaper setup to manufacture and not having to worry about the specs too much. You will not find a floating caliper on a high $ race car that is competing in some kind of serious race class.
Who cares how much clamping force you have as long as you have enough to lock up with race tires and the C4/C5 brakes have that.
Again i have heard that willwood converts have said they still have a soft pedal so you might be disappointed once you get your car together and actually run it hard.
PS: I use them (cast iron Corvette caliper) because I am supposed to BUT believe me an Alcon or a Brembo would be my choice in a heartbeat.
Are you serious?? The C4 brake setup? If there is ONE setup not suited for a sportscar, lacking stopping power, prone to fading and just plain dangerous when you are driving the car hard,...it's the C4 setup. those thin discs get real hot, I don't know if you have ever driven a C4 hard but do it and you will know the true meaning of brake fade, as in hardly any pedal left. Spongy brakes all the way.
I could take anyones brakes and by adding good cheap stainless calipers, good stainless flex lines, truing up the stock rotors and adding a hydraboost and that system would be a vast improvement over what is in that car today and it doesn;t cost thousands of dollars.
Sure for all out racer they still might be marginal remember I was responding with this post to the survey on weather their is a market for upgraded brakes that could run up to $3900 AM.
Twin turbo you want the ultimate in braking power at a high dollar but for that one emergency stop my cheap blueprinted, hydraboost, organic pad setup will give me that one stop just as quick as your mega dollar one. Might not do it again in the next minute but down the road they will cool off enought to do it again. That's mainly what good brakes are all about, that one emergency stop with lots of cool down before the next one.
I have thought about race rotors and hats along with aluminum calipers but it would only be for bragging rights and nothing more.
I think the biggest problem people have with brakes is in not knowing how to diagnose problems...manually bleeding the brake system with this Brake Bleeding Procedure is how brake systems are easily diagnosed. The analysis is simply to figure out where the leaks are coming from, or if there is no pressure at a bleeder valve. The repair is to remove and replace the defective part, like calipers, master cylinder, proportioning valve, lines, hoses, pads, etc. with OEM parts. For example, trying to rebuild the calipers themselves is
Also, once you start changing the system with different parts and 3rd party products then you are essentially re-engineering your systems. I would expect that the majority of people do not have the qulifications to re-engineer their brake systems. I believe the best solution for vette brakes is to replace any worn parts with OEM parts. The only upgrade should be to retrofit to a modern system. Personally, I think the traction control systems on the newer vettes would be sweet.
While hydraboost is not necessary it is a big step up from the vacuum booster and takes alot less room. In fact I couldn't run any vacuum booster with my tall valve covers and I need the tall valve covers for the stud girdle.
I ran mechanical brakes for years and HATED them. They required too much pedal effort and I let others test the car and I was imbarrassed?? by how poor they were.
