Transmission removal progress.
Old Aug 18, 2004 | 03:40 PM
munday's Avatar
munday
Default Transmission removal progress.
Well so far I haven't even jacked up teh car yet. I am taking out stuff that might be in the way or that I just don't need. I just took out the tire carrier. Didn't even have a tire in it...that's 35 lbs that won't be going back in. Kinda cool to see the halfshafts.
Old Aug 18, 2004 | 03:56 PM
munday's Avatar
munday
so i see i have too take out all my exhaust...this sucks since the duals are once piece all the way back from the headers... hope wifey doesn't mind when it is in the living room.
Old Aug 18, 2004 | 04:19 PM
Schmucker's Avatar
Schmucker
Just drop the exhaust off with the transmission crossmember. Assuming it's an automatic with a removable crossmember. Make sure you support the engine at the rear of the oilpan to keep it from pivoting.
Old Aug 18, 2004 | 04:41 PM
munday's Avatar
munday
DOH!!! no exhaust hangers... the ahole that installed welded everything....DAYUMIT!!!!!
Old Aug 18, 2004 | 06:11 PM
NHvette's Avatar
NHvette
Huh ? What Schmucker said. I already suggested that in your
earlier post. The only hangers that should be there are at the
tranny crossmember and at the muffler outlets. You have NONE ?
ps - full welded system is usually good - until you need it out of the way.
Old Aug 18, 2004 | 06:20 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Ain't that the truth
Old Aug 18, 2004 | 06:30 PM
munday's Avatar
munday
dayum i am 1 jackstand shy of getting this thing down...can't find my vette book. should i unbolt the tranny before lowering the crossmember? i don't have a tranny jack and autocrap and oriellys don't rent them.
Old Aug 18, 2004 | 06:44 PM
mrvette's Avatar
mrvette
Tranny jack,....easy....just drill a 3/8 16 hole in center of your floor jack cup, and tap for bolt.....take a 2x6 with recessed bolt through center, and run it down into the cup....then you have something you can wire tie to the tranny....or even drill two holes to catch super long bolts into the pan, if you really paraniod.....ME, I just balance the tranny on the 2x6 and get over with it....
I jack the living crap outta my cars for that operation....
GENE
Old Aug 19, 2004 | 12:46 PM
munday's Avatar
munday
mmm fun, got tired of waiting for the fluid to leak out of the pan so i just taped a hole in it... I'm replacing the POS anyways...has a couple small dents in it.
To Transmission removal progress.
