Header Bolt Length
Old Aug 19, 2004 | 03:04 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Header Bolt Length
What length header bolt do I use on a 427 heads. The(bolts) come in 3/4 to 1 1/2 inches long. Motor is all apart and the new header flange is about 1/4 thick...is 3/4 long enough to do the job?
Old Aug 19, 2004 | 04:28 PM
Steve's74's Avatar
Steve's74
Yes, unless you have A/C or P/S, in which case you will need to use bolts with studs on the end to mount the brackets.
Old Aug 19, 2004 | 05:11 PM
SteveG75's Avatar
SteveG75
Use 3/4".
I bought some 1" ones and they bottomed out even with the 3/8" flange on the Hooker's.
To Header Bolt Length
