Rebuilt Edelbrock Q-Jet Problem
Old Aug 20, 2004 | 12:25 PM
SLine78's Avatar
SLine78
Default Rebuilt Edelbrock Q-Jet Problem
A couple of months ago I rebuilt the Edelbrock Q-Jet I had purchased, and it has been working flawlessly on the 71 until yesterday. I had not started the 71 for a couple weeks but it was a nice afternoon so I intended to swap cars at lunch and enjoy the vert for the afternoon. It initially started but ran extremely rough and then died. After a minute of trying to get it restarted, I lifted the hood, pulled off the air cleaner and noticed gas puddles on both side of the intake manifold. I gave it a quick crank and noticed gas was fliowing out of the vent tube on the carb. I figured maybe I had a stuck float so I tried rapping on the carb around the float area in hopes of getting it unstuck. It seemed to help a little, but gas continued to percolate out from around the accelerator pump if I tried to start the car.
Any suggestion as to the problem or potential solutions before I remove it and open it back up?
Thanks,
Mike
Old Aug 20, 2004 | 12:41 PM
lars's Avatar
lars
One of a few issues:
Stuck float (could be caused by float clip incorrectly installed through hole in float arm)
Dirt in needle/seat
Fuel-soaked (sunk) float
Either way, you need to pop it open and fix it.
Old Aug 20, 2004 | 01:11 PM
SLine78's Avatar
SLine78
Thanks Lars.
The float clip hangs from the center of the hanger with the tip/end pointed towards the front of the carb - correct?
I admit I am confused about the sunk float. Wouldn't this keep the needle in constant contact with the seat, thereby not allowing any gas into the float bowl?
Mike
Old Aug 20, 2004 | 03:23 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
A sunk or heavy float will drop and open the needle, same as a drop in the fuel level.
Old Aug 20, 2004 | 04:42 PM
SLine78's Avatar
SLine78
Of course!
Not sure what I was thinking. It was early, yea that's it. That's my story, and I sticking to it.
Thank Big Fish.
Mike
To Rebuilt Edelbrock Q-Jet Problem
