Rear Gear Ratios
Old Aug 22, 2004 | 09:27 AM
viperjesse's Avatar
viperjesse
Default Rear Gear Ratios
I'm trying to figure out what my rear gear ratio is. I have a 76 auto L48. I spun the tire and counted the driveshaft rotations. For every 1 turn of the tire the diveshaft turns 3 times.
Can you guys tell me what ratio I have? As far as I know it is stock.
Thanks in advance.
Old Aug 22, 2004 | 09:33 AM
73ragtop's Avatar
73ragtop
Most likely is 3:36 to 1
Old Aug 22, 2004 | 09:34 AM
ManFromEagle's Avatar
ManFromEagle
Looks like you have a 3.08 ratio. That's what my 77 came stock with also.
Old Aug 22, 2004 | 09:47 AM
redwingvette's Avatar
redwingvette
most came with the 3.08 which sounds right from your count.
Old Aug 22, 2004 | 10:07 AM
mandm1200's Avatar
mandm1200
More than likely 3.08's. Doing just one spin is not enough to be certain. I would spin the tire 10 times and count the driveshaft revolutions. It only takes a minute or two. The toughest thing is keeping track of the numbers as your spinning.
Old Aug 22, 2004 | 10:50 AM
Mike Mercury's Avatar
Mike Mercury
there's an 'ole "rule-of-thumb" to determine rear axle ratio; that has worked every time I have tried it (but I haven;'t tried this on all vehicles... obviously) ...
Shift into the tranny gear that is a 1:1 ratio; drive 75mph and note the RPM on the tachometer. Divide the RPM by 1000 and that gives you the rear axle ratio.
3300 RPM would equate to a 3.30 rear axle ratio.
For automatic trans with non-locking converters, you need to subtract the tc slippage RPM from the overall RPM reading before dividing by 1000. generally 300 to 400 RPM.
For this to work, you must have maintained the factory rear tire heigth.
To Rear Gear Ratios
