Rear brake caliper mounting
Old Aug 22, 2004 | 06:55 PM
kf4915's Avatar
kf4915
Default Rear brake caliper mounting
I have just installed my rebuilt trailing arms to my frame. I have rebuilt the brake calipers and have new pads.
When I took the calipers off the rotor I had removed the whole TA assembly with rotor and calipers as one unit. I cannot seem to access the caliper mounting holes with the bolt on the forward caliper mounting bolt hole. I cant get a good angle to get the bolt length in, the parking brake guide is also in the way a bit to, it may have been bent a bit.
Is there something wrong here, or should I remove the trailing arm, and install the caliper with the arm and rotor off the car.
Old Aug 22, 2004 | 07:07 PM
75 Hot One's Avatar
75 Hot One
You may have to bend the hydraulic brake line a bit for access. That is not a problem. Nothing else should be restricting access.
