Tach HELP!!!
Old Aug 22, 2004 | 08:05 PM
NotPopz's Avatar
NotPopz
Default Tach HELP!!!
One night my tach is fine, the next day it is stuck at 25. I have a 1979 L-82. It has the original electric tach in it. What do i start with to try and get it back working? I know that the needle does move a little but does not even go down when the car is started.
Old Aug 23, 2004 | 11:49 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Check you connection at the distributor an the ground for the tach filter on the intake manifold behind the carb. t could be that your filter is going bad or perhaps the circuit board on the tach.
