Anyone Know How to Remove a Windshield?
Old Aug 23, 2004 | 10:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Anyone Know How to Remove a Windshield?
I have a craxked windshield that needs to be replaced. Before I do that, I thought that I'd replace the windshield rubber seal and have a look around for any pillar issues. Does anyone know how to renove the windshield? Since I'm replacing the rubber, I suppose that I could just cut it, but therer must be a better way.
Old Aug 23, 2004 | 10:40 PM
bn7035's Avatar
bn7035
Get a piano wire or buy a wire from the parts store that is made for this purpose. You push it against the inside of the windshield. Between the rubber seal and the glass. Have a friend pull it then you pull it back. Kind of like a saw. It cuts the rubber away from the seal. One person can do it with the T-tops off. But it is best to have someone help you lift it off.
Old Aug 23, 2004 | 11:30 PM
lowvette's Avatar
lowvette
I've changed a few windshields and this is how many of the pros do it.
Old Aug 23, 2004 | 11:58 PM
68/70Vette's Avatar
68/70Vette
The stainless steel trim around the windshield is held on by plain steel clip like devices that are riveted on. It doesn't take long for these to rust. Theres a tool to slip under the stainless steel trim to snap it lose from the clips. If the clip is pretty rusty you might break it. I broke a couple - not only because they were rusty but also being a first time trim remover I broke them because I really didn't initially know what I was doing. I've noticed that some of the Corvette part houses now sell these steel clips. You might want to buy some ahead of time in case some get broken when you remove the trim. After removing the trim, I looked at the window for a long time and finally took it to a shop that specialized in windshields. They did a good and fast job.
Old Aug 24, 2004 | 08:07 AM
nd4speed's Avatar
nd4speed
If you have an auto body store near you they sell the tool that is used to break the seal. I found this out after i paid to have mine out. tool was around $15
Old Aug 24, 2004 | 08:25 AM
Ybnormal's Avatar
Ybnormal
Believe me it is worth paying someone to do it. I went throught this last month and it took me two weeks to get mine out and glass was everywhere. First I tried a cold knife but the old seal was so hard it would not cut through it. I ended up using my drimel tool to cut through most of it, then the cold knife. Wish I had just paid someone to do it now. But the bright side is I love the new windshield
YBnormal...drive a vette
Old Aug 24, 2004 | 10:52 AM
stingray4me's Avatar
stingray4me
you can use a guitar string too. See my other recent post on windshields for my story.
Old Aug 24, 2004 | 01:01 PM
LemansBlue68's Avatar
LemansBlue68
Do your hands a favor and cut a couple 6" sections of fat dowel rod or broom handle to wrap the piano wire around so that you and a buddy can work the wire back and forth. The object is to slice through the window seal and not your hands. I had the windshield out of my convertible in no more than 20 minutes by this method. I wish I had removed it before doing all of my work (and cracking it in the process).
Old Aug 24, 2004 | 01:40 PM
mooneyd's Avatar
mooneyd
Low Overpass
Old Aug 24, 2004 | 02:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
[QUOTE=Ybnormal]Believe me it is worth paying someone to do it. .../QUOTE]
Old Aug 24, 2004 | 02:59 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
[QUOTE=Easy Mike]
I picked glass out of my '79 for two years after I did it.
To Anyone Know How to Remove a Windshield?
