Is caliper replacement easy?
Old Aug 24, 2004 | 01:06 AM
aharte's Avatar
aharte
Default Is caliper replacement easy?
I replaced my brake pads today, and found that some of the caliper pistons don't seem to be sealing very well anymore. Also, the pistons on one of the calipers didn't want to retract. My calipers look they were lifted out of the ocean anyways, so I figure I should replace them. Is this easy to do without any special tools? The most complicated thing I've ever done to the car was changing the pads .
Old Aug 24, 2004 | 01:19 AM
Z-man's Avatar
Z-man
In my opinion, this is a pretty easy project. The more difficult parts are...
1) You will need a pretty stout (long handled) socket (or a pipe over the handle) to get the two bolts that hold the calipers on if this is the first time they are being removed. I use a 6-point socket from an air hammer so I don't strip the bolt heads. There isn't anything special here - it just needs to be big enough...I use a 1/2 inch drive.
2) Assembly is easy, but many people get stuck on bleeding them when you are done. I got a set of the check-valve bleeder screws so I could bleed them single-handedly.
3) For 10 bucks a side, I'd also have a shop turn the rotors while you are at it...
Good luck -
Old Aug 24, 2004 | 01:29 AM
aharte's Avatar
aharte
Ok, great. I have the speedbleeder screws already actually. I think I remember reading that there is a special bleeding procedure for when the MC is run dry. Is this correct?
Old Aug 24, 2004 | 01:36 AM
Pedro'74's Avatar
Pedro'74
If that happens, then you have to bleed the MC and start all over. You should try to prevent that from happening, by watching the MC closely while you bleed the brakes, and by plugging the brake hoses temporarily with vise grips while you do the operation.
Replacing the calipers isn't difficult. As mentioned above, the main potential problem is frozen bolts. Start soaking them with Kroil or something like that in advance...
Hope this helps...
-Pedro
Old Aug 24, 2004 | 03:36 AM
Turbo-Jet's Avatar
Turbo-Jet
when installing new calipers, pre fill them via gravity before connecting to the hard lines. this 'wets' the inner surfaces and can save hours of bleeding confusion/frustration. i wonder why more people don't do this...
Old Aug 24, 2004 | 07:47 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
...but I would not put vise grips on my brake hoses. Your life depends on those hoses and I would not do anything to weaken them. Best bet is to get a baggie and stick the end of the hose into it, tie off tightly with rubber band; you won't lose much fluid. Also, leave the lid on the master cylinder. That will create a bit of a vacuum and retard the flow of fluid from the lines.
Old Aug 24, 2004 | 02:57 PM
aharte's Avatar
aharte
Ok, thanks for the tips, guys.
Old Aug 24, 2004 | 09:18 PM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Why you are at it, you should replace your front brake lines with some new ones, if your are original and worn. Go with the HD braded SS if you can afford them.
Frank
Old Aug 24, 2004 | 09:23 PM
aharte's Avatar
aharte
I do plan on replacing the lines. The car already has stainless lines, but I think that one of them might be failing.
Old Aug 25, 2004 | 09:11 PM
EVIL_GRIM's Avatar
EVIL_GRIM
if you are doing the front calipers, have someone help you hold them while you thread the line into the caliper ...unless you got some beefy set of guns on ya cuz holding-.....wait a minute, NOW i know why mine were heavy! they were Steel Sleaved!!! damn.... ok well have someone help you anyways cuz trying to twist the line on while holding a 20 to 30Lb caliper isnt fun, especially since the threads are really fine. twist the brake line up in the opposite direction it will be threaded on and then it will slowly unwind while you thread it on. sounds easy eh? just make sure you have a very thick wall you can put your hand through when u get mad cuz you will...i had concrete...not so forgiving
Old Aug 25, 2004 | 09:19 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
On a related topic... I could use some hints on installing the pads. I just replaced the upper & lower control arms and had removed the calipers and rotors as part of the process. WOW was getting the pistons retracted to re-install the pads a pain! Admittedly I am a novice but even with a buddy's help it was a serious pain.
I thought I saw mention somewhere that maybe syringing some fluid from the MC to provide some relief might be the way to go?
Old Aug 25, 2004 | 09:32 PM
Schmucker's Avatar
Schmucker
Just crack the bleeder when you push the pistons back in.
Old Aug 25, 2004 | 10:15 PM
Paul L's Avatar
Paul L
Rebuild them.
http://temp.corvetteforum.net/c3/joe...ructions.shtml
Thanks EdT. Simple job and the Raybestos seals did the trick. One of the old, inner seals had failed and developed a minor leak. I did a cruise evening today and all is well. One piston (of four) has some minor corrosion but those SS sleeves are as smooth as a baby's bum with talcum powder. I suspect another 10 years is in order.
Old Aug 25, 2004 | 11:19 PM
Stoge's Avatar
Stoge
To me, on a scale of 1 to 10, with 1 being easiest and 10 being a 10 case of beer minimum, this job is a 2. Just be careful to use good wrenches on the brake lines so you don't round them off.
Old Aug 26, 2004 | 11:37 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Make sure you follow the GM shop manual bleeding sequence; it is different than most cars. Addtionally while you have the calipers off you may want to change the hoses. The easiset way to crack these (pre a seasoned mecahnic..it works), on the line side is to heat the fitting up until it blows the hose off. I was ready for it and I still jumped. Once the hose is off you can easily crack the line nut. Remove the clip and put the new lines on. Before learning thsi trick I was working it and working it with no success. I would also invest in a good set of flare nut wrenches. All of these steps will help prevent stripping the nut.
To Is caliper replacement easy?
